94 LS Integra, 01 GSR swap
Has anyone used obd2b harness in 94 chasis?
I installed 01 gsr swap with obd2b harness in my friends integra, it starts fine but it has no power. as soon as u give it gas it boggs, there are no check engine codes. Do u have to change any pins for obd2b harness or is it plug in. Thanks
i have a simmilar question.. i am planning on swapping a 98 obd 2 gsr into a 94 ls.. what steps would i need to do to modify my ls wire harness and run vtec.. i do not have the obd 2 wire harness
it should work. i did a 99 GSR swap into my 94 LS and used the 99 harness and it worked fine. the only thing i had to do was wire up the knock, vtec, and oil pressure wires. everything should plug right up.
*i do assume that you're talking about the engine harness correct?*
You Know I Got SOL!
Oct 6, 2005 06:41 PM
