HKS camgears install.. having issues.
Old Oct 3, 2005 | 10:53 PM
DC2 to AP2's Avatar
Default HKS camgears install.. having issues.
i posted this in the ITR forum, but i also decieded to post it here as well.
will i just laid my cams in the head and put the gears on and they look off alot. is this how they are suppose to be?
camshafts are put in with woodroof slot on the cam pointing up. if you look at the cam gears they arent lined up right.. any ideas?
Old Oct 4, 2005 | 06:10 AM
dwnthehatch's Avatar
Default Re: HKS camgears install.. having issues. (imola-red dc2)
Put on the stock cam gears to compare. Maybe the cams or even the gears are machined wrong.
Old Oct 4, 2005 | 06:12 AM
MenaceL.A.671's Avatar
looks like your ex. is off... line up the two outer dots with the head....
Old Oct 4, 2005 | 07:48 AM
DANG YO's Avatar
Default Re: HKS camgears install.. having issues. (m2slsvtec)
its normal all the motors i have built/helped build are off like that. once u put the timing belt on, line the 2 dots up with the top of the head and it will be okay.
Old Oct 4, 2005 | 08:01 AM
ek4 coupe's Avatar
Default Re: HKS camgears install.. having issues. (dc2kid)
ya what dc2 said once the belt is on it will put tension on everything and it will settle in place
Old Oct 4, 2005 | 08:27 AM
DC2 to AP2's Avatar
Default Re: HKS camgears install.. having issues. (ek4 coupe)
thanks guys for the inputs... i guess i just wanted to know for alittle reassurance.
Old Oct 4, 2005 | 09:02 AM
bs-inc's Avatar
Sweet cam gears.
mouab18c1
32
Aug 3, 2011 06:00 PM
Nigel379
Jul 23, 2007 01:32 AM
Nigel379
Jul 16, 2007 01:45 PM
ZXRider
Dec 19, 2006 02:43 PM
JDMflavor_EJ
Aug 7, 2005 04:29 PM
