Which timing belt do I use for a JDM B20b and a 99 Si B16 head?
I want to do a CRV-vtec with a JDM B20b and 99 Si B16 head. Which timing belt, oil pump, and water pump do I use(from what car) with my setup?
Here is the answer (get the Vtec pumps if you can)- http://www.geocities.com/whiterabbit...r.html#Service
B18C oil pump(same as B20BorZ/B18C5). Timing belt will be determined by which waterpump is used, B18C waterpump/B18C timing belt(recommended) or B18B waterpump(same as B20BorZ)/B18B timing belt(Same as B20BorZ).
Lissav
May 11, 2006 08:09 PM
saer
Oct 15, 2004 08:30 PM
