stainless steel brake line coating ?
Old Oct 3, 2005 | 06:23 PM
clarkekent13's Avatar
Default stainless steel brake line coating ?
I recently purchased a set of techna-fit SS brakelines for my 93 civic ex. I thought they were one of the brands with a clear coating to protect the SS braiding from wear/dirt, but I was wrong. Has anyone tried putting their own coating on New SS brakelines? I was thinki9ng of possibly using the "liquid electric tape" at home depot(more commonly used for dipping the hancdles of pliers, etc in to give them a rubber coating). My only thought on this is that the coating would obviously not be clear, so i would have no way of visually inspecting the SS braiding. Any thoughts, suggestions?
Old Oct 3, 2005 | 09:46 PM
Default Re: stainless steel brake line coating ? (clarkekent13)
bump
Old Oct 4, 2005 | 10:31 AM
gftgrill's Avatar
the ace hardware by me sells tubing you can buy whatever diameter/length you want.
just go to a hardware store and see if they sell this tubing, probably near the plumbing department. then get enough clear tubing that will fit over the lines.
you might need a way to seal the ends of the tubes to the lines so that if there is a break you don't leak fluid all over the place.
I did this on my mechanical oil pressure guage so that oil won't get into my cabin area of that plastic tube breaks. for 4 feet it was about 3 dollars.
good luck
Old Oct 4, 2005 | 12:26 PM
WhiteSol's Avatar
Default Re: (gftgrill)
Not sure how weather resistant you need it, but clear heat shrink tubing would work well if you got the right heat range.
Old Oct 4, 2005 | 12:34 PM
pdiggitydogg's Avatar
where did you get your hoses?
I bought techna's from king motorsports and they have a plastic coat on the outside
Old Oct 4, 2005 | 02:50 PM
Default Re: (pdiggitydogg)
I got mine straight from their website http://techna-fit.com/
As far as clear tubing goes, I'm trying to find something that fits tight around the line, and it seems the size I would need to clear the end fittings would not be snug at all, once in place(unless I'm misunderstanding you). I didnt realize there was clear heatshrink tubing- I'll have to check that out- again hoping that it will shrink enough to fit tight over the braiding.
civexspeedy
Jun 9, 2008 08:54 AM
Miracle
Suspension & Brakes
14
Nov 6, 2006 11:04 AM
BoOsTiN Dc2
May 29, 2005 01:04 PM
Mike D
20
Dec 17, 2004 06:13 AM
jolt-tsp
20
Sep 2, 2003 10:10 AM
