need to know which trannys are compatable w/ b18a1??
Old Oct 3, 2005 | 03:57 PM
auburnBoy's Avatar
Default need to know which trannys are compatable w/ b18a1??
i have 90 integra gs with the b18a1 and im eventually going to rebuild and turbo it. right now i just need a new clutch but was thinking about just upgrading the tranny with a whole new one from a newer model. should i do that or maybe rebuild the tranny.
Old Oct 3, 2005 | 04:04 PM
743power's Avatar
Default Re: need to know which trannys are compatable w/ b18a1?? (auburnBoy)
you can put any 94+ b-series trans on the motor/in that car, provided you use the hasport cable to hydro conversion kit.
in other words, ls, gsr, b16, type r will all work with the hasport kit
Old Oct 3, 2005 | 09:15 PM
auburnBoy's Avatar
Default Re: need to know which trannys are compatable w/ b18a1?? (743power)
thanks
Old Oct 3, 2005 | 09:19 PM
auburnBoy's Avatar
Default what about the clutch type???
if i put for example, a 94+ gsr tranny with my b18a1 and needed a new clutch kit and flywheel, would i order it for the b18a1 or a gsr 94+ tranny?
Old Oct 3, 2005 | 10:56 PM
hybrid_vtec's Avatar
Default Re: what about the clutch type??? (auburnBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by auburnBoy &raquo;</TD></TR><TR><TD CLASS="quote">if i put for example, a 94+ gsr tranny with my b18a1 and needed a new clutch kit and flywheel, would i order it for the b18a1 or a gsr 94+ tranny? </TD></TR></TABLE>
Its the same. Either will work.
IMO go with a b16 tranny.
Old Oct 4, 2005 | 02:08 PM
743power's Avatar
Default Re: what about the clutch type??? (hybrid_vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_vtec &raquo;</TD></TR><TR><TD CLASS="quote">
IMO go with a b16 tranny.</TD></TR></TABLE>
the input shaft on the cable trans is smaller I believe
b-series flywheel, 94+ b-series clutch
helpmycivic
Feb 7, 2008 07:06 AM
ElZRex
Mar 14, 2006 09:52 AM
Drian
Mar 17, 2004 01:34 PM
SPOON_BeIgHtEeNsEe
Aug 27, 2001 09:07 AM
