headgasket+mill,will pistons hit valves??
Old Oct 3, 2005 | 02:45 PM
madjdmy0's Avatar
Default headgasket+mill,will pistons hit valves??
I plan on getting a .010 high compression headgasket and milling the head .020. Im also installing supertech valves with titanium retainers and dual valve springs. Will the piston hit the valves and if not, what size cam can i get maximum so that the valves wont hit the pistons? Thanks,
-Terry
Old Oct 3, 2005 | 02:46 PM
madjdmy0's Avatar
BTW, this is on a JDM h22a .
-Terry
Old Oct 3, 2005 | 04:46 PM
s13_240sx_92's Avatar
Default Re: headgasket+mill,will pistons hit valves?? (madjdmy0)
Try claying the top of the pistons stock, then take that measurement and apply it to what you want to do. You should have your answer there.
Old Oct 3, 2005 | 05:26 PM
madjdmy0's Avatar
Im sorry, but what do you mean by claying? Also, does anyone know with what im doing if the stock bottom end will hold up?? I just plan on getting titanium retainers, dual springs, valves, and im unsure on what cams to get, hondata.
-Terry
Old Oct 3, 2005 | 05:42 PM
M@'s Avatar
M@
Default Re: (madjdmy0)
Put some clay on top of one of your pistons then turn the motor over by hand very carefully. After one full cycle you'll have the lest amount of clearance left on the clay. Then add a good amount for a safety factor.
Old Oct 4, 2005 | 10:43 AM
madjdmy0's Avatar
Default Re: (M@)
Cool, thanks. Ill try to get that done and tell you guys the results.
-Terry
Old Oct 10, 2005 | 04:22 PM
madjdmy0's Avatar
I dont want to rip apart my motor and find out that some stuff wont work properly. Does anyone know the piston to deck clearance for the jdm h22a? If i have that, then i can find out what my compression ratio will end up being with the headgasket i select and if the pistons will actually hit the valves depending on how thin i want to go.
-Terry
jdm.fanatic
Jun 18, 2014 09:28 AM
1A4
Mar 28, 2008 01:18 PM
lyckaon
Nov 20, 2005 11:05 PM
EFin' Kyle
Sep 26, 2005 08:20 PM
