ROD BEARING QUESTION.....
Old Oct 3, 2005 | 12:02 PM
aznwash3wboi's Avatar
Default ROD BEARING QUESTION.....
ok..i know your suppose to plasiguage etc. when puttin on rod bearings.... but a master tech at my workplace (toyota) told me for the rod bearings (buy the same size as old ones) and the main bearings (buy one size up from old ones... like if they were a #3, then buy #4)... he said this because the rod bearings dont usually wear very much, the main bearings are what wear... he said this is a rule of thumb and never goes wrong... any one agree?
Old Oct 3, 2005 | 12:46 PM
Kendall's Avatar
Honda's usually don't wear much on the main journals so you'll almost always end up using the same size bearings everywhere (assuming that bearings weren't the reason for the rebuild). Using plastigauge is always a good idea, it's a small step that can make a world of difference when it comes down to the longevity of the motor.
Old Oct 3, 2005 | 01:18 PM
B18C Turbo's Avatar
Default Re: (Kendall)
Just use ACL's. They are the same as the green bearing and Ive used them in a B16a and a b18c5 and they cleared .0015" both rod and mains. They are awsome!
Old Oct 3, 2005 | 01:35 PM
yea the reason for the rebuild is cuz a spun bearing....
Default Re: (aznwash3wboi)
im prolly gonna go with oem bearings
Old Oct 3, 2005 | 01:39 PM
Kendall's Avatar
Are you reusing the original crank or are you replacing it? At this point you will need to plastigauge in order to make sure all of the tolerances are good. No harm in being safe.
Old Oct 3, 2005 | 09:57 PM
original crank.... gonna grind and micro polish it... yea ima go ahead and plasigauge...cuz some material will be removed.... thanx for the help
Phoenix5
Honda Civic (2001 - 2005)
Dec 23, 2013 11:07 AM
dj-t
Jul 2, 2009 08:48 AM
Mugen112
Oct 18, 2006 11:52 AM
db2integra
Sep 20, 2004 08:25 PM
sir2k
Mar 5, 2003 11:33 PM
