Will a crx cluster fit in my 90 dx?
If you have the 90 DX, stay with the 90-91 cluster regardless if CRX or Civic. The 88-89 had a flat top section, different brackets and housing cover, as well as different wiring. FYI, there are two different OEM manufacturers of these clusters, it would be wise to stick with the same manufacturer as you already have as your car is already pre-wired for it.
Personally, I have found that on Ebay, if you find the "CIVIC" 90-91 cluster out of the Si, they go for less money than the CRX, but that is just my observation. That is how I got my 89 Civic Si for $25 in my STD, the CRX was easily $50+ for the same thing.
turboartie
Mar 11, 2005 03:20 PM
88civicHB703
Apr 26, 2003 10:09 AM
