JDM Type-R K20A !!!
OK I have already looked this up many a times.
I am looking For The K20A JDM Type-R Engine.
I am duin a swap in my 97 DC. I got the mounts from hasport. and they are going to do my wire harnest. But every place i look i can't find the Fu*!@r. I just paid for mounts and the place that i thought would have them. Fucked me.
So a lil help Thanxs guys
http://www.jdmtheory.com
http://www.passwordjdm.com
http://www.inlinefour.com
http://www.jdmland.com
You can email or call any of these companys and they should have them, I know that JDMTHEORY has a few in stock even full DC5 clips!
Hell yeah it is! I would do it in a heart beat if I could for sure get my car bar'd and smog legal here. Since Cali is gay I am going to either have to move or build up my B18C1
From: Salt Lake City, Chicago at heart, UT or IL, USA
back when I had my teg, I thought about doing that swap, but, I realized it would put way too much weight over the front wheels, thus making the car very nose heavy. The integra already, being FWD, and nose heavy will understeer a lot, and the K, being mounted as far foward as it is, will make it much worse. It'd only be good if you were doing drag racing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marsbike »</TD></TR><TR><TD CLASS="quote">back when I had my teg, I thought about doing that swap, but, I realized it would put way too much weight over the front wheels, thus making the car very nose heavy. The integra already, being FWD, and nose heavy will understeer a lot, and the K, being mounted as far foward as it is, will make it much worse. It'd only be good if you were doing drag racing.</TD></TR></TABLE>
Theres a lot of people that would argue that. Considering that the same is said about an H22 in an Integ. I personally doubt it will have any serious impact on handling because of the slight weight difference. Just my two cents.
i think the k-series swap weights like 3 lbs more that a b series swap
The K is not as heavy as the H22, Also like the guy said it's only a few lb's heavy R then a B. Plus whith the power +LSD+BOOST+a suspension upgrade it will do just fine.
I also think that you are mixin up the fact ,that the body of the rsx is heavy.
That I know for sure
I might be wrong I don't know what is really in ur head. BUt thanx for your input.
And yes I have already sent the money for the K20. should be in my home in about 5 days
you are ******* joking right? its been PROVEN that the K series is LIGHTER then any b-series motor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp »</TD></TR><TR><TD CLASS="quote">
you are ******* joking right? its been PROVEN that the K series is LIGHTER then any b-series motor</TD></TR></TABLE>
also to mention i'm not sure about the K but i know for sure that the H22 sits low in the engine bay and tilted towards the rear, which is even better for weight distribution. i also heard some weird **** about VR accord sedan race cars with destroked H22's (to 2.0L, for higher redline) where the V6 engine mounts let the H22 sit totally behind the front wheels. badass!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Li-tunner »</TD></TR><TR><TD CLASS="quote">The K is not as heavy as the H22, Also like the guy said it's only a few lb's heavy R then a B. Plus whith the power +LSD+BOOST+a suspension upgrade it will do just fine.
And yes I have already sent the money for the K20. should be in my home in about 5 days </TD></TR></TABLE>
Uh.... Yeah. I never said the weight was the same, just made a point to Mr. Doohmass that the same so called theory has been said about the H22 and even that has not been proven to have any negative effect in handling. Not mixing anything up just making a point. Notice I said "slight weight difference". Anyways not getting into it any further there is post after post about this same discussion.
I would love to see a teg with a K20 typer r, good luck with that. Peace
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jay_c »</TD></TR><TR><TD CLASS="quote">
um, where the hell do you get your info? lol whoever it is
to them
</TD></TR></TABLE>um, where the hell do you get your info? lol whoever it is
to them
i think the deal with the H22 is like this: it's heavier, yes, but most of the people who do it are doing it to drag race, and those that aren't probably aren't as worried about handling as going fast in a straight line. and the people who race their cars will realize that the power gained by going H22 will far outweigh any difference in handling the weight would make . . . and besides, those people don't have a/c or p/s so the H22 isn't so heavy for them.
to them</TD></TR></TABLE>
huh???
to them</TD></TR></TABLE>huh???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ajantics »</TD></TR><TR><TD CLASS="quote">Acutally the way the Kswap leans is further back then the B18's making it better, and the weight is like a 10 pound diffrence if that! </TD></TR></TABLE>
Throw on a CF fiber hood and your set.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmfonseca85 »</TD></TR><TR><TD CLASS="quote">Throw on a CF fiber hood and your set.</TD></TR></TABLE>
i got a better idea. take that money that you would have spent on a CF hood (minimum $300) and get a treadmaster. it will get you more women AND make your car lighter
huh???</TD></TR></TABLE>
the person who is telling you that a k20 is heavier, etc is full of ****
to them
to them
