Anybody cornerweighted their 5th gen?
It's a long shot since there're lots of better ways to spend cash (hence my asking
), but has anyone cornerweighted their 5th gen? Or if not, anyone know the weight distribution F/R? I'm trying to calculate wheel rates and spring natural frequencies and need to know sprung weight on the wheels. Thanks for any help.
I once was a judge in a science fair and a cute middle school girl had an interesting project. She accurately estimated her dad's truck's weight by air pressure in the tires and the deflection of the rubber. I should have asked for a copy of her report and methods.....
Here's a thread from another board with actual corner weight data for a 1998 Prelude TypeSH and a 1998 Prelude Base
http://www.preludeonline.com/showthr...threadid=29451
Andrew
Andrew
Thanks for that thread, aklucsarits. I'm looking for stock weights before they've been adjusted, but that does give me some other ideas (ah, the never ending pursuit of suspension modification)
heeh..neverending yeah
can we know what you are planning ?
could help others maybe
i had the stock weight somewhere from when i conerweighted the base lude of a friend..
i'll try and find it out today
ah stupid me..
the weight we have are with the coilovers set with height before we adjusted it..
so it's not the stock weightings from the stock suspension
but u can play around with the numbers cause it'll be the same totals neway
Do you have numbers for your friend's car before you adjusted the coilover sleeves, or after? If it's before, then that should work. How did you cornerweight it?
we used electronic balanced.and diagonal method..
that was just to set his car on a good level while helping out the weight distrib
yes i have that book ( my favorite so far
i calculated the natural frquecie once..approximatly
and it was something like .8 in front
and 1.2 in the back
though.that was when i had erroneous stock spring rate
i hope u do know the stock spring rates for prelude
F: 3.6kg/mm
R is 3.1kg/mm
that's make roughly F : 200lbs/inch R: 170lbs/inch
please unless u want to alter car balance try to stick with this ratio as close as possible
just for additional info
mugen lowdown suspension rates : F 3.8 R 3.4
so ratio is a little different
i'd stick with the mugen ratio..and play with sway bar adjustments for correct track balance
could you post here all the number u have so far ?
that would be cool to have accurate numbers
thanks
)i calculated the natural frquecie once..approximatly
and 1.2 in the back
F: 3.6kg/mm
R is 3.1kg/mm
thanks
and 1.2 in the back
F: 3.6kg/mm
R is 3.1kg/mm
thanks
and 1.2 in the back
F: 3.6kg/mm
R is 3.1kg/mm
thanks
Here's the equation I used: W^4G divided by 8ND^3.
W is the diameter of the spring wire,
G is 12,000,000, a constant for steel,
N is the #of active coils+1/2
D is the diameter of the coil, measured to the center of the wire.
My measurements were: W=7/16" Front and rear
N=8 1/2 front, 7 1/2 rear
D=3 5/16" front and 3 3/8 rear
Final answer for stock spring rates were a little surprising:
178 lb/ft Front
190 lb/ft Rear
I was surprised at how low these #'s were (reinforcing my belief that stock sway bars are pretty stiff - the front one anyway) and I was surprised the rear was stiffer. I guess they tried dialing out some understeer.
Wheel rates are 39.12 Front and 26.71 Rear. These are the amount of force necessary to move the wheel up one inch.
[Modified by Steppin Razor, 7:20 AM 3/5/2002]
cool cool
doe
ahah
i didn't get an answer from my friend who has the number for the weight yet..should get it by tomorrow i guess
total weight was under 2900lbs without driver if i recall correctly
didn't have any mods except the coilovers back then
cool neway..you are doing same thing as i did
by the way..
how did u get to you rear/front spring rates
cause u know..i had a friend in japan called MUGEN to know their spring rates and the stock spring rates
the first information i had was that front was 3.1 and rear was 3.4 kg/mm
wich is mmm F: 190lbs/inch and R: 170lbs/inch
i then assumed that for almost a year
until my friend called mugen
and we had different numbers
that is why i thought that all the aftermarket companies were doing ****
cuase they all were doing reversed ratio..front stiffer than rear
when i though it was contrary
neway
so check out ur spring rates..i do not think that they are good
at least for the rear
or then again..mugen is all fucked up
and the otehr place is right..
ahah
ahah
by the way..
neway
ahah
Thanks for the #'s, but I need pre-balanced weights. Looks like I'll just have to spring for getting the car weighed. I'll post up when I have it all done
ok
but you could just do it with thoose
the weights didn't change more than 5% overall
from when we started to move them..
though the car was never weighted stock..it started with coilovers ( skunk)
at same height setting on each wheels
neway i guess that beeing there u can do it preoperly and get perfect results
when u will have the results please let me know with a small msg or something as i don't always read the posts in here ok
see ya
see ya
