Speedometer Problems 94 Civic Hatch
Old Oct 3, 2005 | 08:03 AM
56BUDDY's Avatar
Default Speedometer Problems 94 Civic Hatch
'94 Civic DX Hatchback that has a speedometer that jumps around and sometimes doesn't work at all. VSS has been changed...no change in speedometer. Anyother areas where I should check? Car is all stock/original. Thanks!
Old Oct 3, 2005 | 08:18 AM
riceburnerryan's Avatar
Default Re: Speedometer Problems 94 Civic Hatch (56BUDDY)
i think it may be an electrical problem .. correct me if im wrong but checking the grounds may help?
Old Oct 3, 2005 | 08:36 AM
56BUDDY's Avatar
Default Re: Speedometer Problems 94 Civic Hatch (riceburnerryan)
Thanks for your reply. Now, the grounds that you're talking about. Are you talking about the VSS in the engine compartment or at the speedo, under the dash? Thanks again!
Old Oct 3, 2005 | 10:10 PM
i heard to check the ones from the battery and the valve cover and the tranny ... just check those out ... but im not sure ... anyone else can chime in if im wrong
Manifest113
Jul 21, 2014 09:50 PM
stpacura
Sep 18, 2008 11:58 AM
JohnnysEG
Aug 12, 2008 02:03 PM
RA166E
Feb 8, 2005 12:04 PM
