92 Integra LS - Clutch and shake
Old Oct 3, 2005 | 07:18 AM
ckoulaid29's Avatar
Default 92 Integra LS - Clutch and shake
A friend told me about this site. I just bought a used 92 integra and noticed that the clutch sticks a bit about halfway. Does this just require lubrication? Also, when I accelerate over 45mph, usually when the car is in the higher RPMs I can feel the car/ steering wheel shake. When I let off the gas there the shake stops. Bad motor mount?
I don't really know much about cars, just what I have learned from past problems, so I would appreciate any info. Thanks
Old Oct 3, 2005 | 07:24 AM
BlackLudeSi's Avatar
Default Re: 92 Integra LS - Clutch and shake (ckoulaid29)
It is easy to get at the clutch cable, its right under the battery, on top of the trans. Make sure its not all rusty on moves freely. Other wise check the back of the pedal, there is a big spring, that might be all sticky too.
As far as the shake, a motor mount could definetly cause that, otherwise a slipping clutch could be the cause
Old Oct 3, 2005 | 10:18 AM
projectTeG's Avatar
your shaking problem sounds like axles.
Old Oct 4, 2005 | 11:30 AM
ckoulaid29's Avatar
Default Re: 92 Integra LS - Clutch and shake (BlackLudeSi)
Hey, thanks! I will take a look at those things. I appreciate the quick response!
Joshb152
Oct 13, 2015 05:46 PM
redDAinteg
Apr 6, 2006 01:30 AM
92accord
Aug 10, 2004 11:31 AM
conors
Sep 5, 2003 03:12 PM
