Would 92-93 integra front bumper fit on 90-91???
I have a 90 integra and i wanna put the 92-93 front bumper on it but i heard it wont fit up perfect. i heard something like you have to change the bumper reinforcment bar and brackets. maybe that was for the jdm one or something...i dont know so any help would be appreciated, thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4sd4dr »</TD></TR><TR><TD CLASS="quote">yea, you need to get the 92-93 bumper, support and lenses.
so, uhm... you can make it work with the 90-91, but Im not sure how you would accomplish this.
check out g2ic.com just as many ********* as here, but more tech info on g2's.</TD></TR></TABLE>
actually doing a 92-93 front bumper conversion. all you need is the bumper cover and bumper lights. you should use the 90-91 bumper support becuase if you put on the 92-93 bumper support the side clips wont line up right and there would be gaps on it. you should also use the foam from the 90-91 if you have it. if you use the 92-93 foam then you would have to cut and shape it to fit.
so what u need is:
92-93 bumper cover
92-93 bumper lights
90-91 bumper foam (optional if you have it you can use the 92-93 but you would shape it)
so what u need is:
92-93 bumper cover
92-93 bumper lights
ok, slowly...wouldnt it be easier to swap bumper covers, and keep my 90 bumper support on if everything will fit, rather than do wat you said and swap out my bumper support with a 92-93 bumper support and get mounting plates.
I believe so... only as far as the BUMPER cover.
The only that MAYBE would be different is the molding on the bumper; thats all I can think of.
Check out g2ic.com; I bet we have a **** over there that knows for sure! LoL
