gsr block/b16 head
Old Oct 2, 2005 | 07:50 PM
EG6-SIRII's Avatar
Default gsr block/b16 head
I searched about the poor mans type r and their isn't much info on it.
Is it worth doing?
95 gsr block *stock*
B16a head port/polished
ITR cams
3 angle valve job
Would it be worth putting these 2 together?
Currently i have my JDM B16A2 in my eg and am very happy with it,But i'm wondering if i should go with the type r wannabe.
Is it reliable for a daily driver?
Any and all suggestions will be greatly appreciated
Old Oct 2, 2005 | 09:18 PM
areyoujealous's Avatar
Default Re: gsr block/b16 head (tatersald)
yeah it would be pretty reliable (comprable to your current setup)
Old Oct 3, 2005 | 07:27 AM
EG6-SIRII's Avatar
anyone else?
Old Oct 3, 2005 | 07:35 AM
sockvtec's Avatar
it will be reliable if its done right, and very worth it IMO
Old Oct 3, 2005 | 07:36 AM
Redcoupe's Avatar
What ecu are you running? Are you planning on getting a V-AFC and tuning, or hondata?
tdo's Avatar
tdo
since you got a b16 already and gsr short blocks dont go for much, i'd say go for it. i think its work it. or if your really short on cash just go lsvtec.
Old Oct 3, 2005 | 09:46 AM
EG6-SIRII's Avatar
Default Re: gsr block/b16 head (tdo)
I'm running a P30 ecu and i plan on running uberdata.
Old Oct 3, 2005 | 10:00 AM
T.J.'s Avatar
yes , you will not be disapointed,
Old Oct 3, 2005 | 10:06 AM
what kind of transmission do you have
Old Oct 3, 2005 | 10:49 AM
EG6-SIRII's Avatar
Default Re: gsr block/b16 head (bling bling)
y21 lsd
Old Oct 3, 2005 | 10:58 AM
Doeboy's Avatar
do it, a few people i know have them, they are fast, tune that **** though it will be way worth it.
Old Oct 3, 2005 | 12:07 PM
JETSPD1477's Avatar
your compression is going to be lower than a stock GSR if you dont swap the pistons out. combustion chamber is larger on B16/ITR cylinder heads when compared to factory GSR heads.
Old Oct 3, 2005 | 04:24 PM
EG6-SIRII's Avatar
Default Re: (JETSPD1477)
The compression will drop .2 so i'm not to worried,I plan to boost it in the spring anyway.
Old Dec 4, 2005 | 09:22 PM
EJ1_203's Avatar
Default Re: (tatersald)
planning on the same setup
running stock b16a2 with bolt ons
4g4dcruisin
10
Sep 4, 2009 09:22 AM
jkalex05
Aug 31, 2009 10:15 PM
zeroek
Aug 2, 2005 04:24 PM
tkre420
Mar 4, 2005 09:39 AM
EFin' Kyle
Jul 8, 2004 05:44 AM
