Coolant smell
Old Oct 2, 2005 | 07:49 PM
mathews's Avatar
Default Coolant smell
I did a coolant serive and now when driving I smell coolant from inside the passenger compartment. I dont think anything is leaking but i will check the levels tomorrow. The car is not overheating, infact the gauge doesn't even go the half way point.
Anyone have any thoughts of what could be going on?
Old Oct 2, 2005 | 09:01 PM
ludeman92's Avatar
Default Re: Coolant smell (mathews)
i doubt this is it but you can check and make sure your heater core isn't leaking. just check the passenger side floor for moisture or a strong smell of coolant
Old Oct 3, 2005 | 10:23 PM
mathews's Avatar
That was the first thing I checked. But I seriously can't figure it out. It still smells like coolant (yes I have had a couple people verify the smell). It is not leaking or burning coolant. Damn what celse could it be?
Old Oct 4, 2005 | 10:15 AM
staticrex's Avatar
Default Re: (mathews)
If you spilled any during your service it may just be burning off of what ever it is sitting on. Might take a few days for the smell to go. I would check your fluid levels regularly to see if in fact you are not burning coolant.
Old Oct 4, 2005 | 02:45 PM
SNsLude's Avatar
Default Re: (staticrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by staticrex &raquo;</TD></TR><TR><TD CLASS="quote">If you spilled any during your service it may just be burning off of what ever it is sitting on. Might take a few days for the smell to go. I would check your fluid levels regularly to see if in fact you are not burning coolant.</TD></TR></TABLE>
Yep... When I was doing coolent bypass I spilled quite a bit of coolant everywhere. Took about a week to get that smell rid of. If you serviced it properly and don't see any leaks thereafter, you should be fine.
Uncle Ben's
Mar 25, 2010 10:27 AM
vroomboom
Honda Civic (2001 - 2005)
May 22, 2008 04:44 AM
msmithgsr2131
Feb 19, 2006 08:39 PM
redteg1
Sep 3, 2003 01:57 PM
