Differential SWAP
Old Oct 2, 2005 | 07:26 PM
Super79Dave's Avatar
Default Differential SWAP
Ok next question i have an SI Tranny 4.25 final drive
Si tranny 3rd grinds 5th rattles
I have a DX tranny 3.88 final drive
all good
So can i put the final drive from and pinion from the SI in the DX case
looking at http://www.hondaautomotivepart...R+BOX
at the part #'s i think i probably can anyone ever done this. $$$ i don't want to rebuild the SI at the moment and the gear ratio's themselves are the same according to
http://thenew.gamesbbs.com/~dmoore/tranny.htm
Old Oct 2, 2005 | 08:59 PM
jlicrx's Avatar
Default Re: Differential SWAP (Super79Dave)
except for final drive, DX and Si gears are the same - swap all of the DX countershaft gears onto the Si countershaft and use the DX differential carrier with the Si ring gear (ring gear bolts are left hand thread) - you won't need to do anything to the mainshaft - just be sure that both transmissions have the same number of splines on the input shaft or you will also need a clutch disc
Old Oct 3, 2005 | 08:17 AM
Default Re: Differential SWAP (jlicrx)
Yep thats what i fgured. Anyone ever seen a cheaper final drive gear set out there i found this one http://www.sbmsinc.com/race_shop.html
DirtyD777
Feb 10, 2006 04:01 PM
CRX_Control
Jan 16, 2005 08:18 AM
DOHC_EF
Jul 13, 2004 06:06 AM
Jet Black
16
Jan 7, 2004 10:40 AM
CimorelliCRX
Nov 30, 2002 12:09 PM
