HELP! having trouble with skunk2 manifold after installing
Old Oct 2, 2005 | 04:48 PM
pureluck's Avatar
Default HELP! having trouble with skunk2 manifold after installing
i just install a skunk2 intake manifold into my 99 gsr and now im having to bad idle on the car. When i rev the motor to 1500rpm the car will start to bob after that the car will run good. I check the engine code and it give me code 14 (idle air control IAC). I replace that sensor with a brand new one and it still doing the same thing. I then took the car to a local machanic shop. They check for vacumn leak, all sensor, and make sure the gasket was not broken and cant figure out what is wrong with the car. One of the machanic there said that maybe the manifold is just to powerful for the car and its giving me a bad idle. Now i'm just stuck. so please help me out.
Old Oct 2, 2005 | 05:25 PM
numotive's Avatar
Default Re: HELP! having trouble with skunk2 manifold after installing (pureluck)
might have something to do with the skunk 2 manifold being a single stage, where a stock 99 gsr comes with a dual stage. from what ive heard changing from a stock dual stage to a single stage can cause performance loss in the lower rpm's, but i've never heard of problems with the idle.
Old Oct 2, 2005 | 05:34 PM
Dogginator's Avatar
Daisy... Daisy...
Check your TPS. If you are revving the car, the IACV shouldn't be active.
daleSol
Feb 13, 2013 09:08 AM
sh4mr0ck
Jul 7, 2010 12:15 PM
DVPTeG
Jun 29, 2007 11:26 AM
germanEE8
Feb 25, 2004 08:56 AM
ajchen
Jan 8, 2003 06:05 AM
