clutch DIY?
Old Oct 2, 2005 | 04:04 PM
Chris in NH's Avatar
Default clutch DIY?
is there a clutch DIY out there for a '90 Accord DX? the original clutch (190K) is starting to slip.
i don't want to PAY the man, i want to BE the man.
thanks.
Old Oct 2, 2005 | 06:14 PM
hondadude's Avatar
Default Re: clutch DIY? (Chris in NH)
The best thing you could do is go buy a chilton manual to help prepare yourself.
You will need tall strong jackstands and a floor jack, air compressor and an impact would be nice too. A 36mm socket for the axle nuts and a 12point 10mm for the pressure plate bolts.
You can justify the tool costs against the labor money you are saving.
Old Oct 2, 2005 | 06:35 PM
Default Re: clutch DIY? (hondadude)
i have a Haynes manual. is that any good?
Old Oct 2, 2005 | 07:03 PM
momstaxi's Avatar
yes it is good...you will definatley save money if you can get it done as clutch jobs are $$$
Old Oct 2, 2005 | 07:11 PM
Default Re: clutch DIY? (momstaxi)
i was told $5-600 installed.
since the clutch kit is only $150, i can't justify spending the other 4-5 hundred.
Old Oct 3, 2005 | 09:19 AM
maroonaccord2.2's Avatar
it's a lot of work, take it from me......
Old Oct 3, 2005 | 09:31 AM
fw190bvi's Avatar
eh....itll work, but ive always found shortcommingsw with it
Old Oct 3, 2005 | 09:48 AM
yardy8301's Avatar
$4-500 is def a lot for a tranny install. it is a lot of work though.
if you are around ft lauderdale fl, i know someone who will do it for $250 labor. yes he is a certified mechanic.
boyrsxsPanama
Jun 10, 2007 07:30 PM
wkrpfm
Acura TL, RL & ZDX
Dec 3, 2004 09:35 AM
whitericelova
Honda S2000
Nov 14, 2004 01:14 PM
ieatrice
Nov 29, 2003 09:01 PM
HeelToe
Jul 1, 2003 07:12 AM
