getting ready B16
Nice 2nd gen b16.
How are you going to run it?? OBD1 or are you going to swap in 88-91 electronics and run the pr3 or pw0 ecu?? What mounts are you going to use? HCP, HAsport, Place racing, or a knock off brand?? As for the linkage you can cut and weld your exisitng linkage or you can buy an HCP or Hasport premade shift linkage.
Oh yea, by the way that transmission will not work unless you can custom fab a kit to drop a hydraulic actuated transmission into a car that has a cable actuated clutch. Good Luck with it.
[Modified by 91civic, 6:55 PM 3/3/2002]
I personally would have just spent less money on the 1st gen b16a but that is my opinion. I would suggest running OBD1 and getting a conversion harness that will convert your exisitng harness to plug into the ecu. A guy with the screen name Blown90hatch was making these harnesses. Shoot him an IM and he should be able to help you out with the harness.
Hahahahahahaha.....
Well you should have told us that in the first place.
Well since the motor was free and you also have a b18 I would put the b18 in instead. Which b18 is it by the way??
Hey, I got a 99-00 SI engine harness if you want to buy it. It plugs right into the ECU. That way, you won't need the jumpers or connectors. Selling for $150 shipped.
dc2jdmhonda hit me back at http://www.mrcrx8@aol.com if u interested bout the trans.
Its me DUB
Mar 2, 2007 08:42 AM
miller
Dec 20, 2004 09:09 PM
hahaha
