Skunk2 Valvetrain on Poor Mans Type R Questions...and injector size
Old Oct 2, 2005 | 02:51 PM
1337 Si's Avatar
Default Skunk2 Valvetrain on Poor Mans Type R Questions...and injector size
Ok, so I plan on getting the Skunk2 stage 2 cams and valvetrain over the winter. Now, what I need to know is, with the JDM 95 GSR block, JDMITR pistons and rods, and new bearings what is a safe assumption that I can spin this to? Say I want to go to 9500 is the bottomend sound? I took the crank angle sensor and timing belt gear off a spare b16 I had lying around The sleeves are in great shape (no scarring, still see cross hatching, ETC) but what rpm are they good to? Also, I would like to know what size injectors I need to run. I was thinking 310 or 440 with a uberdata or s200 on it. Also anticipate running an ANR header and Ericks Racing 70mm TB. Any suggestions for anythign I may need? Let me know!
Old Oct 2, 2005 | 06:41 PM
1337 Si's Avatar
Default Re: Skunk2 Valvetrain on Poor Mans Type R Questions...and injector size (1337 Si)
TTT
Old Oct 2, 2005 | 06:56 PM
Luserkid's Avatar
I would run 310s until you up the compression to 13 or so then you might need higher injectors.
Safe place to rev can only be told by a dyno.
Old Oct 2, 2005 | 08:18 PM
1337 Si's Avatar
Default Re: Skunk2 Valvetrain on Poor Mans Type R Questions...and injector size (Luserkid)
Heh I tell you what you are the man when it comes to responding to my posts
1stGenCrxRobby
18
Aug 28, 2015 02:35 PM
bpoweredeg6
Mar 22, 2011 01:27 PM
mynameizstitch
Sep 23, 2009 08:39 AM
Th3savinday
Mar 3, 2007 11:45 AM
boosted k20
Sep 15, 2005 02:07 PM
