ls distributor in b16 head?
Old Oct 2, 2005 | 11:27 AM
1sikhatch's Avatar
Default ls distributor in b16 head?
well i got a ls distributor from my friend and he cut one of the legs off the housing to fit in my b16 head, but i want to know if the distributor will work properly as the b16 dizzy? performance and gas mileage wise... the reason is someone stole my b16 distributor
Old Oct 2, 2005 | 01:42 PM
rdeezy78's Avatar
Default Re: ls distributor in b16 head? (1sikhatch)
i agree. it's just like doing a obd-1,2 conversion. should be fine as long as the dizzy is the same obd as the ecu and everything else.
Old Oct 2, 2005 | 02:11 PM
1sikhatch's Avatar
Default Re: ls distributor in b16 head? (rdeezy78)
aight thanks alot for the responses, im glad i dont have to buy a new distributor
Old Oct 2, 2005 | 04:30 PM
Kendall's Avatar
The bolt pattern is different and it will not fit correctly without modification. Everything plugs right up though.
Old Oct 2, 2005 | 04:32 PM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rdeezy78 &raquo;</TD></TR><TR><TD CLASS="quote">i agree. it's just like doing a obd-1,2 conversion. should be fine as long as the dizzy is the same obd as the ecu and everything else. </TD></TR></TABLE>
OBD-2 dizzy's work just fine with OBD-1 ECU's and vice versa. The only difference is the plugs.
Old Oct 2, 2005 | 05:43 PM
jeffhaut's Avatar
i have a b18a dizzy on my b16a. the adjsutment doesnt go as far advanced as the b16a so my timing is off by about 10 degrees. keep an eye on that because it kills performance and milegage
Old Oct 2, 2005 | 06:18 PM
1sikhatch's Avatar
Default Re: (jeffhaut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeffhaut &raquo;</TD></TR><TR><TD CLASS="quote">i have a b18a dizzy on my b16a. the adjsutment doesnt go as far advanced as the b16a so my timing is off by about 10 degrees. keep an eye on that because it kills performance and milegage</TD></TR></TABLE>
damn that was one of my concerns
juanintec
Aug 15, 2007 07:37 PM
Top Ramen
Sep 15, 2006 02:33 PM
jccrxtuner916
Oct 16, 2005 12:23 AM
