HELP! Exhaust leaking like crazy? Please help w/ flange gasket
Old Oct 2, 2005 | 11:09 AM
RA122324's Avatar
Default HELP! Exhaust leaking like crazy? Please help w/ flange gasket
Alright I just swapped a B20 into my '88 CRX Si. I pulled the engine out a running '93 Integra. I'm guessing they re-used the exhuast manifold and downpipe because it's so damn rusty. My problem is everytime I give it anything more maybe 10% throttle the engie doesn't respond. If I floor it and hold it the engine just dies. I went to AutoZone, Adnvace Auto Parts and a bunch of other parts stores. They gave me this:
Me and another guy tried reusing a gasket from some other car but it really ain't working out to well:
I originally though it should look more like this one:
Pardon my drawing, brought to you courtesy of Windows paint.
Can anyone tell me if I'm using the right gasket? Or if the problem is probably coming from some where else? I have all my vacuum lines hooked up except for the fact that I have no intake. Could that be it, i really don't know. Please help.
Oh yeah, I'm under the impression since I see what "looks" like two gaskets on top of the downppipe that I need of two. The reason I only have one is because it's the only one i this ******* town. Here's a pic of a header I saw online. I can't tell if it's for a B16 or B18, if it even makes a difference.
Old Oct 2, 2005 | 11:22 AM
RA122324's Avatar
bump
Old Oct 2, 2005 | 11:28 AM
Phoenix_ITR's Avatar
Default Re: HELP! Exhaust leaking like crazy? Please help w/ flange gasket (knwldge54)
it honestly sounds like you have more of a problem than a simple exhaust leak. an exhaust leak shouldn't cause the car to shut off -- it'll just make an annoying noise.
Old Oct 2, 2005 | 11:45 AM
RA122324's Avatar
Any guess on what it could be then?
Old Oct 2, 2005 | 12:01 PM
Lauj87's Avatar
too rich or lean maybe. or even clogged fule lines. Check the fule pump if its getting enought volts. all i can think of.
Old Oct 2, 2005 | 01:32 PM
RA122324's Avatar
I thought about fuel since it was sitting for almost 5 months. I added some 93 octane gas (7 gallons) to fill the tank. And I added 2 bottles of octane booster. I wish I though about draining the fuel earlier.
I changed the fuel filter right before I drove it for the last time at the end of May but who knows. It's a cheap and fast replacement so I'll try that tommorow.
Old Oct 2, 2005 | 02:36 PM
SingeBgd's Avatar
Default Re: HELP! Exhaust leaking like crazy? Please help w/ flange gasket (delinquent)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delinquent &raquo;</TD></TR><TR><TD CLASS="quote">it honestly sounds like you have more of a problem than a simple exhaust leak. an exhaust leak shouldn't cause the car to shut off -- it'll just make an annoying noise.</TD></TR></TABLE>
Tru
Old Oct 3, 2005 | 02:06 AM
RA122324's Avatar
Default Re: HELP! Exhaust leaking like crazy? Please help w/ flange gasket (SingeBgd)
Could it be this? I just remembered breaking while trying to get the engine in.
Old Oct 4, 2005 | 11:06 PM
watsvtecEK's Avatar
looks like you got a ******* hole in your chassis
prplhrtcivic
Apr 22, 2008 04:41 PM
doggydog
Jan 20, 2005 07:31 PM
blykins
May 1, 2004 05:48 AM
BLACKLUDE97
Oct 5, 2003 09:04 AM
Bigstothel
May 23, 2002 05:54 AM
