crx b20 swap question...
i tried searching but could find what i was lookin for .. how hard will it be to swap a b20 into a 91 si ...ive heard it drops in fine but then you have a hood clearance problem ? need some help
thanks
thanks
it will fit fine should have no major hood clearance problems maybe the vavle cover will rub the bottom hood bracing depending on the mounts you use
i did b20b4
hasport efb1 mount kit
http://www.hasport.com/Product...1.htm
stock hood
it cleared for me
but it will eventually make a dent in the stock hood
or maybe im too abusive on my cars, not really sure...
stock hood
it cleared for me
kool thanks ..yah i just picked up the rex yesterday it has sohc zc with a vtec head in it right now but like i said i wanna drop that b20 it in real soon ...so its basically drop in right ? (the b20 )
ok just ordered the b20 and i already have a LS tranny ...another question should i use the pr4 ecu for this swap ? also wut else do i need ... ls axles , ls alternator, distributor, injectors and maybe starter?
JDM00SI
Nov 19, 2005 08:25 AM
