Interior Painting
Old Oct 2, 2005 | 10:44 AM
Rukusmasta2's Avatar
Default Interior Painting
I have been searching for an SI interior for so long and my car is going to be on road soon and i am gonna have to put the one i have in...i hate the friekin blue color that it is...so im just gonna paint it black...any one ever done this?? any tips...and is it true that 88-89 are different dash and panels thatn 90-91?
Old Oct 2, 2005 | 11:15 AM
eda6's Avatar
Default Re: Interior Painting (Rukusmasta2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rukusmasta2 &raquo;</TD></TR><TR><TD CLASS="quote">any one ever done this?? any tips...and is it true that 88-89 are different dash and panels thatn 90-91?</TD></TR></TABLE>
i thought about paint and vinyl die but then i decided it's ghetto. So i put in work hunting down parts. A year later it's still not complete. A good pair of door panels and decent carpet is hard to find. I'm probably going to buy the rest from majestic honda.
yes 88-89 panels and cluster cover are different. The instrument cluster and cover is different on 90-91 and 90-91 have door mounted seatbelts. If you have an 88-89 don't hesitate to buy rear panels from a 90-91. A dremel will quickly make a 90-91 rear panel fit in an 88-89.
Old Oct 2, 2005 | 11:16 AM
RA122324's Avatar
Whatever you do don't spray paint it.
Just source parts froma junkyard, Honda-tech and/or eBay.
Old Oct 3, 2005 | 07:40 AM
Default Re: (knwldge54)
yea but cant find nothin and this blue makes me wanna throw up
Old Oct 3, 2005 | 07:41 AM
CRX Toad's Avatar
Default Re: Interior Painting (eda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">
yes 88-89 panels and cluster cover are different. The instrument cluster and cover is different on 90-91 and 90-91 have door mounted seatbelts. If you have an 88-89 don't hesitate to buy rear panels from a 90-91. A dremel will quickly make a 90-91 rear panel fit in an 88-89. </TD></TR></TABLE>
Old Oct 3, 2005 | 07:48 AM
corey1031's Avatar
Dont paint it. There is no good way of doing it. Save your money and get new or good used interior.
Old Oct 3, 2005 | 07:51 AM
dsowers19's Avatar
Default Re: Interior Painting (CRX Toad)
Why would you waste that much money on all new parts? There are a few basic
steps you need to take before you paint your parts.
1. Sand down the pieces with a light grit sandpaper such as a scuff pad or some
280 or 320 grit sandpaper.
2. Used lacquer thinner to wipe the parts down before painting. Make sure they are CLEAN!
3. Spray the parts with a couple coats of plastic parts adhesion promotor.(can be found at most local parts stores)
4. Then you can spray them with the color you choose. You can also you a layer of clear coat over the top for the last coat to give it a shiny look and make it last longer.
If you follow these steps you shouldnt have any problems with the paint falling off.
Old Oct 3, 2005 | 07:52 AM
dsowers19's Avatar
Default Re: Interior Painting (corey1031)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by corey1031 &raquo;</TD></TR><TR><TD CLASS="quote">Dont paint it. There is no good way of doing it. Save your money and get new or good used interior.</TD></TR></TABLE>
There is a good way of doing it...you just dont know how
Old Oct 3, 2005 | 08:26 AM
virginia_dude's Avatar
Default Re: (Rukusmasta2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rukusmasta2 &raquo;</TD></TR><TR><TD CLASS="quote">yea but cant find nothin and this blue makes me wanna throw up </TD></TR></TABLE>
Trust me..the factory blue looks far better than painting it is going to look. even a year down the road with vinyl spray..it wears through or peels off where its not properly prepped..adn trust me..you wil not get it 100% correct. What results is absolutely horrible down the road. THe plus side is blue interio stuff is easy to find.
Old Oct 3, 2005 | 10:37 AM
Default Re: (virginia_dude)
dsowers...did u do it???got any pix to back up your skills
Old Oct 3, 2005 | 10:50 AM
dsowers19's Avatar
I could get pics up this weekend as I am at college right now with my crappy winter
beater. I painted mine white and it has been just fine for two years now.
UsDm_Junky's Avatar
dont paint it thats just cheap looking
Old Oct 3, 2005 | 10:51 AM
EFB16ACRX
Guest
Posts: n/a
i spray painted mine black. except for one spot where its worn through to the blue, you could never tell it was a blue interior, ill get some pics later.
JPerkMr954
Paint and Body
13
Mar 17, 2013 07:54 PM
MWLW20
Paint and Body
Mar 2, 2009 11:16 AM
JCL
Paint and Body
10
Nov 20, 2007 07:58 PM
wingback44
Oct 11, 2005 07:36 PM
Piston_Honda
Nov 17, 2001 09:07 PM
