96 Accord LX 4 cyl - Timing belt changed - Getting whistling noise
Old Oct 2, 2005 | 08:01 AM
honda96lx's Avatar
Default 96 Accord LX 4 cyl - Timing belt changed - Getting whistling noise
Timing belt, balancer belt, drive belt changed last month at 105000 miles. Had new water pump installed.
Did 3000 miles after belts installation. Noticing these problems:
(1) Engine seems to whistle when I am doing over 40 miles/hour
(2) Enging pinging when accelerating from 40mph to 50mph at 2200 RPM
Meineke tried but couldn't fix/figure out the root cause.
Please let me know what may be wrong.
Old Oct 2, 2005 | 08:58 PM
schmels_3's Avatar
Default Re: 96 Accord LX 4 cyl - Timing belt changed - Getting whistling noise (honda96lx)
free bump!!!
Old Oct 2, 2005 | 09:04 PM
deserthonda's Avatar
Default Re: 96 Accord LX 4 cyl - Timing belt changed - Getting whistling noise (schmels_3)
double chk ur work,,,,,,,,,,t-belt too tight??? balancer shafts out of balance ?? how did u tighten timing blt??? how did u reset the balancer shafts to align properly??
Old Oct 2, 2005 | 09:05 PM
oops forgot,,,,,,,make sure as well that the main t-belt is properly installed and timed
Old Oct 4, 2005 | 09:05 PM
honda96lx's Avatar
Default Re: (deserthonda)
Thank u. I'll check with Meineke and have them fix it asap.
Old Oct 5, 2005 | 05:38 AM
YeuEmMaiMai's Avatar
Default Re: (honda96lx)
For serious stuff like that, I would only go to the Honda dealer for work.
Old Oct 5, 2005 | 06:16 AM
Default Re: (YeuEmMaiMai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">For serious stuff like that, I would only go to the Honda dealer for work.</TD></TR></TABLE>
u don't have to go to a HONDA DEALER for anything except warranty work,,,,there are a lot of indipendent shops that specialize on HONDAS that do the job better than the DEALER and CHEAPER and still use HONDA parts ........
jsqu03
Jul 11, 2014 01:37 PM
Nathan007
Nov 28, 2008 04:26 AM
wrsimmons21
May 21, 2006 03:47 PM
zmeli
Apr 11, 2004 01:42 PM
