help with twm itb's fuel rail is too big for injetors?
hello i went to install my twm 50mm itb's on my c5 yester day nd found out that the injectors are too small for the fuel rail and the base of the injectors with the rubber grommet is too big for the intake manifold. i have got it all put together with a patched up fuel system that leaks its *** off but the idle is at like 3-4k. also will the tps work if i just pin it out from the stock tps.
thanks
chris
thanks
chris
Stevemyster
Jun 5, 2011 06:49 PM
hotrod99
May 18, 2007 04:18 AM
