ZC giving code 9: No. 1 cylinder position and runs like sht
Old Oct 2, 2005 | 12:05 AM
drjondurst's Avatar
Default ZC giving code 9: No. 1 cylinder position and runs like sht
I just got done replacing the head gasket in my zc-equipped crx and the ecu is throwing a code 9 and the motor is running pretty crappy and almost dies if I let it run long enough. I did a search and found that it could be my cam timing. Are there any other possibilties.. anyone have any personal experience with this code?
Old Oct 2, 2005 | 12:11 AM
BDietrich84's Avatar
Default Re: ZC giving code 9: No. 1 cylinder position and runs like sht (drjondurst)
http://www.we-todd-did-racing....3D%3D
Old Oct 2, 2005 | 04:19 AM
Sikocivic's Avatar
If it just started doing it after you did the headgasket, I would think its cam timing. Recheck the timing marks on the pulley and cam gears. If that not it, then you may have a bad dizzy. If the dizzy was bad, it usally goes into limp mode and won't rev past 3000 RPM. See if you can borrow a dizzy from somebody and try it to see if thats it.
I still think its timed wrong though
Old Oct 2, 2005 | 09:28 AM
jlicrx's Avatar
Default Re: ZC giving code 9: No. 1 cylinder position and runs like sht (Sikocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sikocivic &raquo;</TD></TR><TR><TD CLASS="quote">If it just started doing it after you did the headgasket, I would think its cam timing. Recheck the timing marks on the pulley and cam gears. If that not it, then you may have a bad dizzy. If the dizzy was bad, it usally goes into limp mode and won't rev past 3000 RPM. See if you can borrow a dizzy from somebody and try it to see if thats it.
I still think its timed wrong though </TD></TR></TABLE>
if it is DOHC ZC, it is the cam timing - exhaust cam is off one or more teeth - code 9 is cylinder position sensor, which is located on the end of the exhaust cam on the DOHC ZC, not in the distributor like SOHC engines
trav_89_crx_b7
Sep 26, 2011 02:54 PM
blasterman87
22
Sep 25, 2009 07:50 AM
JCCOOL43
Nov 7, 2006 05:32 PM
daniel89civ
Apr 19, 2003 05:47 PM
311
Feb 27, 2002 05:07 PM
