Honda civic D16Y8 swap jdm D15B, crank & head compatability
Old Oct 1, 2005 | 07:27 PM
THC07's Avatar
Default Honda civic D16Y8 swap jdm D15B, crank & head compatability
I have a 97 honda civic d16y8, I blew a ring. i got a d15b cheap off this old man that said it would fit.
I got the motor running on 16 degree timing, the d15b did not have crank sensor, i guess its in the distrubuter wich must be ok cuz its running. althought i had to splice into the wires and change plugs because the wire harness did not suport the D15b distrubitur. Now i want to use my D16Y8 head on this d15b block???? can this be done, what do i have to do about the crank sensor, and can i use either distrubuter. i want to use the d16y8 if i can.
theres also no whole in the back of the block for the knock sensor??
zb12691
Oct 26, 2010 12:56 PM
trav39562
Jan 27, 2009 04:58 PM
LSR-Abuser
Aug 21, 2007 08:28 AM
THC07
Oct 14, 2005 02:07 PM
