d16z6 sawp in a 89 crx si havin problems!!!!!!!!!
Old Oct 1, 2005 | 06:41 PM
b20vtec crx's Avatar
Default d16z6 sawp in a 89 crx si havin problems!!!!!!!!!
hers the whats goin on i did the obd0 to obd1 swap with the conversion harness from rywire and i also used the obd1 injectors abd eliminated the resistor
but im gettin to much fuel and its flooding my motor and causing it to smoke real bad out the exhaust also it idles real high, plus im gettin codes 3,6,7,9 any help would be appreciated thank you
Old Oct 1, 2005 | 07:40 PM
HiProfile's Avatar
Default Re: d16z6 sawp in a 89 crx si havin problems!!!!!!!!! (allshowcrx)
I can't recall exactly, but aren't the TPS and MAP connectors virtually the same? Accidently swapped them? IIRC, the TPS should have yellow, green and brown wires.
I'm wondering if there's a chance that the IACV and a water temp connector were switched too? The thermostat temp sensor is probably within reach of the IACV.
As for the code 9, I couldn't really say. It should use the stock wires and not throw a code. I'd say check the rotor for any shaftplay - my z6's dizzy bearing was toast. Started with orange dust in cap, then infreqent codes, then squeeking (rotor contacting cap points), then a real code 9 (rev limit to 3k). Swap with a lifetime Autozone core fixed it all, as I thought. Its funny how a rebuild dizzy (before corecharge) almost double my swap cost
Old Oct 1, 2005 | 08:20 PM
hatchblack's Avatar
a little more information would help. what map sensor are you using? did you switch to the 4 wire o2 sensor? are you running an obdI distributor? which ecu are you using? if you have swapped over all the parts, i would personally just start checking all the wires and connectors to make sure they are plugged in to the right places and all the grounds are hooked up right. perhaps the fuel pressure regulator is allowing too much fuel to run through? you said you changed injectors and removed the resistor box, so what injectors did you put in? are they the injectors for the z6 motor?
Hondamonster
25
Apr 1, 2022 12:23 PM
timodonnell
Nov 14, 2012 09:20 PM
wfocrx
14
Jun 19, 2006 08:57 PM
madswapper
May 29, 2005 12:43 PM
SuicideSlide
Nov 4, 2004 03:31 PM
