92 civic
I just bought some of those led lights, the four individual ones, and it says to hook them up to any 12v powersource, but i am having trouble trying to find a power source that will turn them on, only when the lights are on. I have a 92 civic lx.
There is a park light free pin on your under dash fuse box, there are 3 or 4 free pins, [male flat spade term.] there is a 12V+ constant, a 12V+ acc., a 12V+ 2nd ign., and a 12V+ park/dash light output/input, controlled by light switch, [first and second click of light switch], but not effected by dash light dimmer control.
94
94
Can u please tell me what these free pins look like, I checked and I am pretty sure what u are talking about, are they the four light green slots above the fuse box, and which one is for the second switch light function
Sorry I can't find a pix of a fuse box, but they are right on the fuse box itself just above the fuses, they are flat male spade connectors inset into the box, they look like the terminal on a speaker and you use the same type of female term. as you would on a speaker wire to plug into it, [250 female quick disconnect] as for which one is the park light, that depends on the year and model, but as all use the same term. just plug it in and turn on the lights, when you have the right one, the leds will turn off and on with the lights.
94
94
enemysquad
Oct 10, 2007 01:22 PM
