d16y7 build-up
im starting to build my sohc turbo motor for my 91 crx dx. i am using a y7 block with a z6 head, my question is tho, when i got the block it had no pulleys on it or anything, could i use the pulleys off of my dx and would they work right. thanks in advance, and ill let you all know my setup here soon
You could use them, but I'd advise otherwise. You'll be decreasing the life of the motor due to balancing issues, but I'm talking 25% off of a 200k life. You'll probably sell it, swap it, or blow it before the pulleys do anything.
h22a_junkie
Aug 21, 2007 01:02 AM
(is the
