CROWER stock idle cams worth the extra cash ?
Old Oct 1, 2005 | 03:42 PM
sleepystyle's Avatar
Default CROWER stock idle cams worth the extra cash ?
i duno if i wanna blow 200$ more for the stock idle cams then the non stock idle
need opinions plz
Old Oct 1, 2005 | 04:06 PM
Eddiebx's Avatar
i dont see why stock ilde lobes shoudl cost you anymore than non-stock idle lobes. but the nonstock idle lobes will make more power under vtec
Old Oct 1, 2005 | 04:47 PM
Default Re: CROWER stock idle cams worth the extra cash ? (h22accordking)
stock idle cams r 720$ while the nonstick r 499$
Old Oct 1, 2005 | 05:09 PM
mkazm83's Avatar
I read that youll be able to pass smog with the stock idle lobes. I cant verify this tho.
Old Oct 1, 2005 | 05:14 PM
Eddiebx's Avatar
i would suspect you can pass smog fine with stock idle lobes, because well they are the same as stock,
Old Oct 1, 2005 | 05:26 PM
so i wouldnt be able to pass E tests with the non stock idle cams ?
Old Oct 1, 2005 | 05:57 PM
BLACKISWHACK's Avatar
catalytic converter + with obd2 should pass fine...
Old Oct 1, 2005 | 06:19 PM
but im obd1
can i be tuned with hondata and pass the tests with the non stock idle cams
Old Oct 1, 2005 | 06:23 PM
skunked's Avatar
the stage 3's idle like stock. I have been told you can pass smog with the 3's so I don't see why you couldn't with the 2's.
Old Oct 1, 2005 | 07:48 PM
Eddiebx's Avatar
i honestly couldn't tell ya if u can pass smog or not with the non-stock idle lobes as i have never tried to do so. i can get stage 2s or 3s to idle like stock, but never really bothered to get a sniffer on it, sorry
Old Oct 1, 2005 | 09:00 PM
i heard you can pass fine. modified or not. the stock idles lobes are only made to make the idle, obviously, like stock. just go for it. dont blow $200 for nothing
Old Oct 1, 2005 | 10:30 PM
jdmcivicferio's Avatar
Default Re: (Eddiebx)
"i dont see why stock ilde lobes shoudl cost you anymore than non-stock idle lobes. but the nonstock idle lobes will make more power under vtec"
explain how they will make more power I would love to no
Old Oct 1, 2005 | 10:32 PM
matix's Avatar
Default Re: (BLACKISWHACK)
Put my stage 2 non stock idle lobes in. Idles like stock and more low end power. Why would u wanna pay more for the stock idle lobes.
Old Oct 2, 2005 | 12:06 AM
Default Re: (matix)
^^^^ hey thats the reason i made this post cuz i dont want to blow 200$ for nothing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">the stage 3's idle like stock. I have been told you can pass smog with the 3's so I don't see why you couldn't with the 2's.</TD></TR></TABLE>
you sure i can pass with the 3s ? maybe i should get them instead of the 2s same cost.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">i honestly couldn't tell ya if u can pass smog or not with the non-stock idle lobes as i have never tried to do so. i can get stage 2s or 3s to idle like stock, but never really bothered to get a sniffer on it, sorry </TD></TR></TABLE>
how exactly can u get stage 2 and 3 non stock to idle like stock ??????
Old Oct 2, 2005 | 10:52 AM
Old Oct 2, 2005 | 12:08 PM
TOP END MS's Avatar
I dont see Crower cam shafts on there site .. did you get custom grinds?
Old Oct 2, 2005 | 01:17 PM
dude r u blind http://www.crower.com whats in the very middle ?
Old Oct 2, 2005 | 02:24 PM
phryxis's Avatar
crower stg 2s NON stock lobes, type s pistons, etc etc etc, tuned with emanage.
idles fine, and i passed smog!
Old Oct 2, 2005 | 03:27 PM
matix's Avatar
Default Re: (phryxis)
They idle fine u will just notice a slight diffrence in the sound at idle. A little more lopey at idle is all.
Old Oct 2, 2005 | 05:17 PM
skunked's Avatar
Default Re: (matix)
On a cold start my 3's lope a bit however once the motor is warm I can't tell the difference over the stock cams.
Old Oct 2, 2005 | 06:14 PM
alright then im geting the non stock and saving 200$ thanks alot guys. feedback well apreciated
skags
May 26, 2014 01:08 PM
sleepystyle
Oct 1, 2005 05:09 PM
sleepystyle
Oct 1, 2005 05:08 PM
my ride
Jul 3, 2004 01:55 AM
Calavera
Mar 29, 2003 12:31 PM
