my tach n speedo dont work help!
i got a 95 gsr and i took it the shop to get fixed cause my vtec stopped working and the tach and speedo dont work...I did a search.... and i did the speed sensor, didnt fix it... My question is being its not the speed sensor could it be the wiring or a fuse ?
It sounds like it is definitely the wiring. You may want to print out a schematic and start from there. That is the best route you will want to go trust me. You can start by checking your ground and then your amps etc. Somewhere when you or whomever wired your ****, did not do it right.
Dam you replaced the speedo too? I think it is more than likely your electrical. Take out all your wiring and tach and then see if you can fix the problem. I think you can get a schematic online but dammm!!! I dont remember the ****** site. If worse comes to worse, go to the dealer for the schematic they should have it.
Matthew98DX
11
Oct 26, 2014 07:55 PM
clgarner
Apr 2, 2008 05:39 PM
