Timing belt cover removal...arg!!!
Old Mar 3, 2002 | 09:02 AM
charjacq's Avatar
New User
Default Timing belt cover removal...arg!!!
Hi guys, how I am supposed to remove the timing belt cover? Do I need to remove the crankshaft pulley? I hope there is another way. I am in a swap right now and I need to put my 91 left engine mount on the 92 motor. Therefore I need to remove the timing belt cover to have access to the mount bolts.
Thanks
Old Mar 3, 2002 | 09:30 AM
markedOO1's Avatar
Default Re: Timing belt cover removal...arg!!! (charjacq)
try cutting a decent size hole around the mount....big enough to get it out...
Old Mar 3, 2002 | 01:13 PM
bryant's Avatar
Default Re: Timing belt cover removal...arg!!! (marked001)
What engine?
Old Mar 3, 2002 | 07:15 PM
balistic CRX's Avatar
Thanks
you have to remove the crankshaft pulley in order to remove the timing belt. but if you dont want the hassel of pulling the crankshaft pulley out, than just cut the cover thats if you dont really care about it and that you just want to put the damn think on.
Old Mar 3, 2002 | 08:33 PM
charjacq's Avatar
New User
Default Re: Timing belt cover removal...arg!!! (balistic CRX)
That's pretty much what I did. I cut a whole in the cover of the old engine, but when through the hassle of removing the crankshaft pulley of the new engine. I'm putting in a D16Z6 for those that asked.
Charles
Old Mar 3, 2002 | 10:26 PM
JohnBlaze's Avatar
DUDE, just take pulley off! its the only way. cutting it will leave plastic shavings in the cover and it could fug your timing belt up eventually. just do it right!
HTH
slimbunnies
Jan 17, 2013 09:47 AM
tpnorth
20
Aug 8, 2011 11:13 AM
my00SI
May 18, 2009 11:54 AM
charjacq
Mar 3, 2002 09:15 AM
