big brakes
anyone have good suggstion on a brake upgrade,i dont really want to go aftermarket,what i want to know is how hard is it to put ls brakes on my rex?now correct my if im worng but if u use the whole rear susp. i can buy after market shocks and springs foir an ls not a crx.is this swap bolt on from ls to crx?does anyone know how much bigger the ls rotor is to the crx rotor?and if i use the ls portion bvalve will i have to run new brakes lines cause i hear it wont bolt in stock crx location,u have to mount it to the firewall.any help on this would be great.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteckillenzc »</TD></TR><TR><TD CLASS="quote">any info on gsr brakes would be help full. anyone know iff 00 si brakes will fit crx?</TD></TR></TABLE>
The rears will fit just use your stock LCAs, springs/shocks.
The fronts will fit but I would recommend using either 90-93 Integra knuckles with the 00si brake hardware, or 90-91 EX knuckles.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteckillenzc »</TD></TR><TR><TD CLASS="quote">anyone have good suggstion on a brake upgrade,i dont really want to go aftermarket,what i want to know is how hard is it to put ls brakes on my rex?now correct my if im worng but if u use the whole rear susp. i can buy after market shocks and springs foir an ls not a crx.</TD></TR></TABLE>
I suggest getting new trailing arms and using existing control arms, this way your existing shocks/springs will work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteckillenzc »</TD></TR><TR><TD CLASS="quote">does anyone know how much bigger the ls rotor is to the crx rotor?</TD></TR></TABLE>
ls rotors are 10.3" crx rotors are 9.5" iirc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteckillenzc »</TD></TR><TR><TD CLASS="quote">if i use the ls portion bvalve will i have to run new brakes lines cause i hear it wont bolt in stock crx location,u have to mount it to the firewall.any help on this would be great.</TD></TR></TABLE>
The 4040 proportioning valve bolts up nicely to the firewall and brake lines fit perfectly.
Shocka1998LX
Aug 15, 2004 10:43 AM
