1990 Accord idle problem
I have a 1990 Accord Ex Auto. and just resently i started to have problems with it idleing. The car will stay running but the thing is the rpms goes up about 500 and back down 500 and continues to do that til the car is put into a gear. it first started doing that when i rav the engine up from a cold start but now when its at running temp. it does it only when its in park im not sure what it is but i hear that it might be the oxygen senor
Thanks
Thanks
make sure ur idle is adjusted properly ,,if it is too high the rpm will surge..........also chk vor vaccum leaks, also remove the top cover on the fast idle valve and turn in the big valve ,,,try those see if it helps
Honda_Civic95_Ex
Jun 19, 2006 01:47 PM
SlackerAccord
Sep 22, 2005 08:49 PM
