custom air to air intercooler
Just thought I would share a few pictures of an air to air intercooler I am working on for a friends twin turbocharged Mustang. All welding was done with a synchrowave 250DX.
Tony Reiners
Tony Reiners
Yes indeed. It looks incredible! Major props to you! Can you give us specs of the material thickness, tungsten size, amperage, filler size, etc.
Thanks!
Kyle
Thanks!
Kyle
Thanks for the kind words, .125" sheet cut on a waterjet, 3/32" 4043 filler, 3/32" pure tungsten, watercooled torch, small gass lens with #6 cup. The tank to the core took about 150-175 and the tanks themselves were 120-140.
Tony Reiners
Modified by TurboPinto at 6:26 PM 9/30/2005
Tony Reiners
Guest
Posts: n/a
Have you ever seen Eagle one wheel spray? If you clean off all the pieces with the "D" etching spray and rince off good .It makes it allot easier to weld and then after your done do the same thing.And it makes the allum.all even color.And it won't get those burn marks where the weld is.The welds look nice and even.Do you feed the rod the whole way? So you don't have to stop every 4"?
I guess I don't mind the look of the cleaning the arc provides for the weld. Just something pretty standard looking with AC welding to me. I try to weld without stopping whenever possible, but I did have to stop a couple times when welding the tanks to the core, everything was just to hot for me to touch or I ran out of filler. I may have to try the wheel cleaner on a smaller project to see if I like it.
Best regards,
Tony Reiners
Best regards,
Tony Reiners
Looks awesome, but did you drill your holes for the inlet/oulert before you welded the tanks on? Cleaning shavings out of an IC could be a bitch.
You the same guy who's been around Joey's shop, or is it a coincidence you have a green pinto and are from SD as well?
Cleaning the shavings out hasn't ever posed a problem. Yes I worked for Joey for about 6 months. I left there toward the middle of July. I currently work for Dakota Digital.
Best regards,
Tony Reiners
Best regards,
Tony Reiners
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK »</TD></TR><TR><TD CLASS="quote">whats that white stuff on the core next to the welds?</TD></TR></TABLE>
isn't that from the heat that the weld generates? its just escaping through the metal...or something along those lines
RICE POLICE SIP
Feb 29, 2004 04:09 PM
