PM7 ECU on MPFI Conversion
Old Sep 30, 2005 | 02:19 PM
baby50's Avatar
Default PM7 ECU on MPFI Conversion
Question of the day; will a PM7 ECU work do a 88 d15 motor with MPFI conversion. Current PM6 ecu is having issues and figure if im going to invest in another ECU might as well get the most for my money. Anyone????
Old Sep 30, 2005 | 04:58 PM
NikoZai's Avatar
Default Re: PM7 ECU on MPFI Conversion (baby50)
http://www.hondata.com/techecuid.html
PM7 is a DOHC ZC ECU. It's always a toss-up wether or not a DOHC ECU will work on a SOHC. The fuel map is too different. It'll either run rich or lean... one thing is for sure, it won't run right.
If you just want to see if the car will fire (ignite fuel just to make sure you're getting spark AND fuel) that's fine, nothing wrong with it, don't expect it to stay running or drive it like that. But it'll probably fire if you think the PM6 ECU is the problem.
Old Oct 1, 2005 | 06:53 PM
baby50's Avatar
Default Re: PM7 ECU on MPFI Conversion (NikoZai)
thanks niko, the current PM6 is having issues and local 4th gen owner has extra PM7 that for sale and is the only thing availabe for me to use current PM6 is throwing invalid codes and car is runing inconsistent at best. I will have to park the car until i can save the 125.00 for good PM6, at least that is what they want for one her in Atlanta.
Thanks again.
Old Oct 1, 2005 | 09:10 PM
crxdriver89's Avatar
hey man, you should check ebay for the pm6, i picked up a perfectly fine ecu for 20 bucks. just make sure the seller has good feedback, no reason to spend 125 on something you can get for a fraction of that.
Old Oct 4, 2005 | 08:59 AM
baby50's Avatar
Default Re: PM7 ECU on MPFI Conversion (crxdriver89)
will do, I bought this current problem child ecu off ebay from some dufus that painted it blue and its a mess. Looks like paint may be on connection terminals. would this cause ecu to throw codes??
Old Oct 4, 2005 | 09:09 AM
crx-treme's Avatar
i have a pm6 for sale......do your pms work?
Old Oct 4, 2005 | 01:10 PM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
Default Re: PM7 ECU on MPFI Conversion (crx-treme)
ive used obdo pr4 and pg7 ecus, which are both dohc ecus and have worked perfectly fine. user bserieskiller uses a b16 ecu with his z6.
Nooch
Nov 11, 2011 03:27 PM
nick91civicsi
Engine Management and Tuning
Oct 25, 2009 03:27 PM
Hybridize
Oct 19, 2003 05:10 PM
-=ELF=-
Mar 2, 2002 05:07 PM
Ribkracker
Jan 19, 2002 03:45 PM
