which subwoofer enclosure is the best??
Old Sep 30, 2005 | 02:01 PM
JCracer723's Avatar
Default which subwoofer enclosure is the best??
just like the title says.. which enclosure can i get more bass out of? 10 inch
Old Sep 30, 2005 | 04:11 PM
donalduck_69's Avatar
Generally, if you want more bass, i'm thinking you want more db's. If so, ported would be your solution, the paperwork that came with the sub should tell you the dimensions for it. It will be tuned to put out more db's at a certain frequency. Good luck.
Nate
Old Sep 30, 2005 | 04:12 PM
mrdeadman's Avatar
They let me pick
Default Re: (donalduck_69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donalduck_69 &raquo;</TD></TR><TR><TD CLASS="quote">Generally, if you want more bass, i'm thinking you want more db's. If so, ported would be your solution, the paperwork that came with the sub should tell you the dimensions for it. It will be tuned to put out more db's at a certain frequency. Good luck.
Nate</TD></TR></TABLE>
i thought bandpass was supposed to be the craziest bass setup. buy a 15.
Old Oct 1, 2005 | 05:55 PM
fcm's Avatar
fcm
Old Fart
Default Re: which subwoofer enclosure is the best?? (JCracer723)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCracer723 &raquo;</TD></TR><TR><TD CLASS="quote">just like the title says.. which enclosure can i get more bass out of? 10 inch</TD></TR></TABLE> What 10", make and model?
What do you mean "more bass", louder, lower, or louder and lower with the least amount of power?
Read this, it may help... although it may not be your speaker the basics, pros and cons apply to all speakers. http://www.kicker.com/05/tech-...1.pdf 94
cityslicker1606
Audio / Security / Video
Mar 20, 2008 10:07 PM
youraquickone
16
Jun 17, 2005 03:20 PM
TuCKiNaLL4s
Apr 1, 2005 06:59 PM
noob with an RS
Jan 19, 2005 11:27 AM
CaptainObvious
Oct 26, 2003 01:35 AM
