whats the dimensions of the Dual Din Radio Block Off Plate
Old Sep 30, 2005 | 01:30 PM
IntegraTypeR's Avatar
Default whats the dimensions of the Dual Din Radio Block Off Plate
hi guys i wanted to ask who owns this Dual Din Radio Block Off Plate on whats its dimensions cause i would consider doing my si climate swap to fit a TV screen in there
Default Re: whats the dimensions of the Dual Din Radio Block Off Plate (IntegraTypeR)
here's a pics of what am talking about:
Old Oct 11, 2005 | 12:41 PM
any one have one and can measure it using a ruler or something?
Old Oct 12, 2005 | 02:14 PM
bump1
Old Oct 12, 2005 | 10:40 PM
MR Dan's Avatar
66.116.69.217
just go buy one at the Acura dealer...around 14 bucks or less.... from a 90 integra RS...
Old Oct 13, 2005 | 03:10 AM
Default Re: whats the dimensions of the Dual Din Radio Block Off Plate (ITR908)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR908 &raquo;</TD></TR><TR><TD CLASS="quote">just go buy one at the Acura dealer...around 14 bucks or less.... from a 90 integra RS... </TD></TR></TABLE>
dont want to buy one by the way.....just wanna know whats its dimensions so i can fit something else in there!
Old Oct 13, 2005 | 02:32 PM
bump
Old Oct 14, 2005 | 04:46 PM
bump1
Old Oct 16, 2005 | 02:32 PM
bump2
Old Oct 17, 2005 | 08:08 PM
whats the height x length of this guys?
Old Oct 18, 2005 | 09:00 PM
RiceRocketDave's Avatar
Just do a search on what the din size is. Or better yet measure the hole that your radio is in.
Old Oct 19, 2005 | 08:53 AM
Default Re: whats the dimensions of the Dual Din Radio Block Off Plate (ricerocketdave)
i know that two din height is nothing but two din...its fixed i know....so in that two din height i can fit two stereos if each of them are 1 din....but the reason am asking is i wanna fit a tv/lcd screen in there and most LCD screens are given in 6.5, 7" sizes and dont know those numbers mean and if they will fit or not in that 2 DIN space?
Old Oct 19, 2005 | 09:00 AM
LOL if you know the dimensions for a din then do this DIN X 2= 2 DIN
That will be the answer that you are looking for.
Old Oct 19, 2005 | 12:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricerocketdave &raquo;</TD></TR><TR><TD CLASS="quote">LOL if you know the dimensions for a din then do this DIN X 2= 2 DIN
That will be the answer that you are looking for. </TD></TR></TABLE>
lol....nice one.....am trying to say i know the DIN sizes and DONT understand the LCD screen sizing where they give sizes like 7" LCD screen...and would like someone to explain to me if that is width or heigh size or is it the size of the screen itself or is it the size of the outer case of the screen?
Old Oct 19, 2005 | 12:54 PM
B18C_EJ8's Avatar
It's just like your tv at home... It's usually measured diagonally.. The screen size may be 7" corner to corner, but the actual size of the housing vary from brand to brand...
Old Oct 19, 2005 | 01:26 PM
Default Re: (B18C_EJ8)
True...What I would do is look into the screen that you are looking at. The manufacturer will usually put the exact dimensions of the screen in all the info for the screen on their website.
Old Oct 20, 2005 | 12:08 AM
Default Re: (ricerocketdave)
Now i bought an Si climate control (the complete part) and right now i cant compare since i dont have it yet, so can someone tell me if this screen will fit or not: http://cgi.ebay.com/ws/eBayISA...:US:1
it says its Dimensions: 20.2CM x 14CM x 2.8CM so will this fit in the Si climate control in the Two Din space?
Km
Old Oct 20, 2005 | 08:55 AM
Default Re: (IntegraTypeR)
A double din spot is this big. 7.2" X 4.22" or 18.29cm X 10.72cm so no it will not work unless you custom mold it into the dash.
By the way it took me 5 min to find out all this info on http://www.google.com
Search next time
Old Oct 29, 2005 | 06:39 PM
http://forums.nasioc.com/forum...t=din
it says here that 1 din is 190mm x 60mm (7.5" x 2.36") ! why there is a difference between your values and that post?
Old Oct 30, 2005 | 04:40 PM
http://www.installdr.com/TechDocs/999006.pdf
This took me five min to find on Google And if you are still not sure about this GO MEASURE THE OPENING IN YOUR CAR!!!!!!!!!!
Old Nov 1, 2005 | 03:01 PM
cant open the file! asking me for username and password....and by the way how can i measure the console since my console is the 98 version!!!!
Note: curently am doing an Si climate contrl conversion
turboteg90
Feb 18, 2008 09:06 PM
gregory
Oct 5, 2006 07:41 AM
2Point2EH2
Jun 21, 2006 06:18 PM
ninesecteg
Jun 16, 2004 08:46 PM
ej one
Feb 14, 2004 03:17 PM
