FS: Eagle Rods for H23/F22 including JE 87mm pistons $300
I used these pistons / rods literally for like 300 miles. I experienced a sleeve sink (poor machine work) and went with another setup after. Here are the specs of the pistons. I'm in a bit of a pickle and need money to pay for a new turbo manifold, so my loss is your gain $300 SHIPPED TO THE LOWER 48!
These are all like new and ready to go, I'd obviously advice buying a new set of rings.
JE
P/N# 212886
Engine Type: Honda H23A1
Head: 2.3L DOHC Non-VTEC
Bore: 3.425"
Rod Length: 5.630"
Dish Depth: .120
Pin Dia: .866
Pin Length: 2.250
Rods are Eagle "ESP" with ARP 2000 bolts.
Pics:
http://www.ecimulti.org/albums...d.jpg
JE
P/N# 212886
Bore: 3.425"
Rod Length: 5.630"
Dish Depth: .120
Pin Dia: .866
Pin Length: 2.250
Pics:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GimpyAccord »</TD></TR><TR><TD CLASS="quote">
JE
P/N# 212886
Bore: 3.425"
Rod Length: 5.630"
Dish Depth: .120
Pin Dia: .866
Pin Length: 2.250
isnt h23 rod length 5.572?
Modified by raceACCORDingly at 11:26 AM 10/3/2005
JE
P/N# 212886
Bore: 3.425"
Rod Length: 5.630"
Dish Depth: .120
Pin Dia: .866
Pin Length: 2.250
These are 9.0:1, and I know the rod length isnt correct on the spec sheet. However these were in my H23A1 (1992 motor) with the H23 crank. I was just as confused as you guys, but they worked fine. The only thing I can assume is a misprint on the sheet as it plainly says H23A1 non-VTEC for its "use". One thing I can assure you is that they were in a H23 block with an H23 crank.
The reason these were pulled is #1 sleeve sunk about 3mm (shitty sleeve install).
I'm trying to be as forthcoming as I can here and I have nothing to hide. The rods have no literature with them except that they're "eagle ESP H beam rods"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ludster »</TD></TR><TR><TD CLASS="quote">Are these custom? </TD></TR></TABLE>
Yes, it was a custom invoice.
If you guys want I could scan the invoice, I just have to go get it at home over lunch.
crimper999
Sep 29, 2008 08:55 PM
