throwing codes after swap
Old Sep 30, 2005 | 10:18 AM
1SIKEF8B20VTEC's Avatar
Default throwing codes after swap
just swapped a B18a1 in my 90 crx si, swapp went well, car fired up on 2nd crank, only issue is intermittently idle will start going up and down between 1000-1250 rpm, accelerates nicely no issues, performance good, im getting codes 5,7,14
witch i believe are MAP,IAC,and TPS, would ou guys say its a vacuum issue, or sensor problem, only intermittently does the idle bounce, thanks fella's.
Old Sep 30, 2005 | 10:27 AM
88 rex's Avatar
Default Re: throwing codes after swap (northerntouch)
Sounds like you mixed up your plugs. Double check them and the triple check them. Then test the voltages and make sure that all the prongs in teh sensors aren't bent (happened to me)
MilanoRedDashR
Honda S2000
May 17, 2013 06:58 PM
JdmCrx209
Jun 22, 2012 05:33 AM
MadScientistGuy
35
Dec 3, 2011 06:25 PM
itzyaboyzeem03
Sep 15, 2009 01:51 AM
boosh
Dec 24, 2003 09:31 AM
