nology wires
Old Sep 29, 2005 | 09:24 PM
willie_d18's Avatar
Default nology wires
i have the whole msd set up . but i need a good set of wires. i know the msd wires work good , but would nology wires work good, or would they be to much to work with msd setup.(mess up something)
Old Sep 29, 2005 | 09:30 PM
Del Sol SiR's Avatar
Default Re: nology wires (willie_d18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by willie_d18 &raquo;</TD></TR><TR><TD CLASS="quote">i have the whole msd set up . but i need a good set of wires. i know the msd wires work good , but would nology wires work good, or would they be to much to work with msd setup.(mess up something)</TD></TR></TABLE>
they should work fine, as long as they are spiral core. the older nology wires are solid core, which is supposed to be bad on msd systems.
Old Sep 29, 2005 | 09:31 PM
delsolb16's Avatar
ya i would like to know to. What about spoon wires?
EL Vap133's Avatar
Sell them, they don't make a major difference.
Old Sep 29, 2005 | 09:39 PM
C2daIzZle's Avatar
wires are wires.
Old Sep 29, 2005 | 10:19 PM
enhancedCL9's Avatar
magnecor kv85
Old Sep 29, 2005 | 10:36 PM
92'si's Avatar
Well i'm partial to msd wires but... nology are best because they hold the charge and let it go all at once, so they have best gains.
But i did notice better "up and go" with my msd wires, prolly cause i replaced dizzy cap and rotor when i put them in though.
Old Sep 30, 2005 | 12:28 AM
Ace0246's Avatar
Default Re: nology wires (JDMeh3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMeh3 &raquo;</TD></TR><TR><TD CLASS="quote">magnecor kv85 </TD></TR></TABLE>
werd.
Old Sep 30, 2005 | 02:37 AM
Proglow3's Avatar
If your looking for wires that are the same just do a search. Look for wires that are the same on ohms and also match as far as insulation or RF resistance and...bamm there you go.
Old Oct 1, 2005 | 12:02 AM
Swapped_EG's Avatar
I would stay away from NOLOGY. i had a set and i hated them. For some reason they had too much resistance. I have MSD wires now and they are great and cheaper. Magnacore is good too and not as expensive as NOLOGY.
Old Oct 1, 2005 | 12:34 PM
T.J.'s Avatar
sell your whole msd system and put oem wires back on. Oem ignition is all your going to need.
Old Oct 1, 2005 | 01:25 PM
Evilsol1994's Avatar
Default Re: nology wires (T.J.)
The niology wires work good i haave them with an entire msd set up they work nice and they look crazy too with there own grounding straps
Old Oct 1, 2005 | 01:35 PM
_gurusan_'s Avatar
Default Re: nology wires (Evilsol1994)
i just use NGK "blue" wires. Cheap...last for a long time...and good wires.
OEM honda ignition is just fine til you start making over 380-400 whp.
Except the damn ignitors....fuckign things suck ***
Old Oct 1, 2005 | 02:06 PM
transpar_nt's Avatar
Seriously, Hondas have some of the best oem ignition systems around. If your engine is stock or near stock, you will receive zero benefits from "upgrading" to anything else. Moreover, Honda's spark plug wires are better than almost any aftermarket ones. Nology is a joke. Sport Compact Car did a test of these a long time ago and they weren't even as good as most crappy ones.
Old Oct 1, 2005 | 03:16 PM
_gurusan_'s Avatar
Default Re: nology wires (transpar_nt)
i remember that....I think some cheapass Accel wires made about .8 whp less or something...which doesn't even mean anyhting on a dyno
Old Oct 1, 2005 | 04:20 PM
QwkD16's Avatar
I was also wondering about the nology wires but someone also told me to stay with the factory setup.
Old Oct 1, 2005 | 06:06 PM
T.J.'s Avatar
Default Re: nology wires (_gurusan_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _gurusan_ &raquo;</TD></TR><TR><TD CLASS="quote">i just use NGK "blue" wires. Cheap...last for a long time...and good wires.
Except the damn ignitors....fuckign things suck ***</TD></TR></TABLE>
oem ignition is fine at 650 whp
Akalima
Sep 9, 2006 08:44 AM
redDAinteg
Jul 5, 2005 02:47 AM
JDM96SpecCTR
Nov 27, 2004 09:25 AM
B_1_8_hatch
Sep 21, 2003 09:31 PM
EminemGSR
Oct 31, 2001 05:08 PM
