twin turbo'd GSR
Old Sep 29, 2005 | 09:11 PM
goowakjai
Guest
Posts: n/a
Default twin turbo'd GSR
i met this kid at my school today who claims he has a mini cooper with a twin turbo'd GSR...i think what hes saying is legit cuz he aint sum kid who just talks cars liek he knows...him and his dad has been racing for years and he seems to know his shyt...i personally never seen any honda engine(or an four banger) twin turbo'd has anyone seen it done? whats the performance benefits if any...he says hes gon bring me sum pix soon i'll try to c if i can borrow em and upload it on to here...
Old Sep 29, 2005 | 09:15 PM
You Know I Got SOL!'s Avatar
Default Re: twin turbo'd GSR (goowakjai)
i just saw a mini with a k20
Old Sep 29, 2005 | 09:20 PM
db8xc1x39
Guest
Posts: n/a
Default Re: twin turbo'd GSR (You Know I Got SOL!)
twin turbo? fucc....**** his motor must hold more psi than is in your tires i hope...i wonder what his setup is like. crazy post any info you get on that asap id like to see what it looks like.
Old Sep 29, 2005 | 09:22 PM
numotive's Avatar
advantage would be 2 cylinders per turbine, as opposed to one turbine for all 4 cylinders. basically more psi... thats crazy tho, i'd like to see that
Old Sep 29, 2005 | 09:25 PM
check out this beast!
http://mwsns.com/forums/viewtopic.php?t=21302
Old Sep 29, 2005 | 09:29 PM
AntiStock's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">advantage would be 2 cylinders per turbine, as opposed to one turbine for all 4 cylinders. basically more psi... thats crazy tho, i'd like to see that </TD></TR></TABLE>
Maybe, but probably the reduced exhaust gasses (only coming from 2 cylinders as opposed to 4) would probably cause some pretty serious lag and inefficiency unless he was running a smaller turbo (at least a smaller exhaust side), but then you run into the problem of not having much room on the other side (meaning you get spoolup, but lose on ultimate power gain). Most twin turbo setups are sequential (sp?) with a smaller turbo for the low ranges of RPM switching to a larger turbo for the upper reaches. Definitely would be cool to see how (if) he made it happen!
Old Sep 29, 2005 | 09:31 PM
White cracker yeehaa's Avatar
thats fukn insane!!!!
Old Sep 29, 2005 | 09:38 PM
LSTEG96's Avatar
Default Re: (DC2KinG)
Im going to wave a giant BS flag at TT I4's.... lets see pics,
and then lets see vids of it beating any old single turbo monster setup.
Old Sep 29, 2005 | 09:54 PM
The-LS's Avatar
Default Re: (LSTEG96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSTEG96 &raquo;</TD></TR><TR><TD CLASS="quote">Im going to wave a giant BS flag at TT I4's.... lets see pics,
and then lets see vids of it beating any old single turbo monster setup.</TD></TR></TABLE>
I'm with this guy, have yet to hear of any pro teams with $$$$$$$$$$$ up the *** building a twin turbo I4, and those Twin Turbo I4's that I have seen built have only cons and more cons... never out performing a single turbo setup in any scenario. Lets see a VIDEO! I won't even settle for a photoshopped picture.
Old Sep 29, 2005 | 09:56 PM
db8xc1x39
Guest
Posts: n/a
Default Re: (Black-LS)
pho sho!
Old Sep 29, 2005 | 10:03 PM
goowakjai
Guest
Posts: n/a
Default Re: (db8xc1x39)
yea, i';ll try to get more info on this ASAP...im goint o try to see if its coo if i can go take a look at this in person...yea, i have heard the idea of twin turboing i4s for years, but every scenario has nuthin but cons and more cons...i wud love to see a dyno sheet for his engine, see if the twin smaller turbos power band compared to a single turbo'd B18...on other note, i read in a mag that sumone is in the works of twin turboing a WRX STi, and its goin to be sporting 1 of only 2 chargespeed wide bodykits in the states, cant wait to see that hit the mags
Old Sep 29, 2005 | 10:09 PM
zeroz's Avatar
quite a few big companies twin turbo integra engines before i'll get some pics up as soon as i find it again
Old Sep 29, 2005 | 10:14 PM
zeroz's Avatar
Default Re: (zeroz)
here we go apexi drag integra http://www.overboost.com/pix.a...t.jpg
"GT Race Team attempt to control the monster 600HP twin turbo Drag Integra down the 1320! With a best time of 9.006 @ 156.15 mph"
Old Sep 29, 2005 | 10:15 PM
fergy016's Avatar
Most of you are thinking of it at set-up as 2 exhausts ports per turbo.
Think of it in series. You have two different sized turboes. One small for no lag, and one big for when the small one doesn't have anymore more push.
This will give you no turbo lag and awesome performance from forced induction.
This concept has been around for a long time. Just applying it is pricey.
Old Sep 29, 2005 | 10:16 PM
zeroz's Avatar
Default Re: (fergy016)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fergy016 &raquo;</TD></TR><TR><TD CLASS="quote">Most of you are thinking of it at set-up as 2 exhausts ports per turbo.
This concept has been around for a long time. Just applying it is pricey.</TD></TR></TABLE>
kinda like the dual staged supra only 500 or so of those were made though
Old Sep 29, 2005 | 10:28 PM
goowakjai
Guest
Posts: n/a
sounds like the super/turbocharger concept they useto use in the rally cars
Old Sep 29, 2005 | 10:33 PM
db8xc1x39
Guest
Posts: n/a
Default Re: (goowakjai)
sicc
Old Sep 29, 2005 | 11:15 PM
shamoo's Avatar
Will you make something up for me please?
Definitely possible, but as mentioned before, there are far more disadvantages than advantages in this sort of setup. It's been proven time and time again that more power can be made from a well set up single turbo system than a twin turbo system on an I4 car such as ours.
It's analagous to having a turbocharger AND supercharger. Sure it sounds like a great idea, it sounds like it'll have massive power, but in the end, having just one and tuning it well will produce lots more power (and more reliably as well).
Not that I'm doubting what you're saying, but I would be interested in seeing pics as well, from a pure curiosity standpoint. I'd like to see how the exhaust is routed.
Old Sep 30, 2005 | 01:56 AM
LL2009's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by db8xc1x39 &raquo;</TD></TR><TR><TD CLASS="quote">sicc</TD></TR></TABLE>
Old Sep 30, 2005 | 02:29 AM
97tegGS's Avatar
Default Re: (LLEO245)
Was at a local car show. Crazy craftsmanship. Never got to talk to the owner though.
Old Sep 30, 2005 | 05:50 AM
beaterman's Avatar
Default Re: (97tegGS)
a guy on homemadeturbos.com had a twin turbo ls. it was pretty sick lookin but i never saw the dyno or a 1/4 mile time.
Old Sep 30, 2005 | 05:57 AM
DA-nteg's Avatar
Default Re: (beaterman)
Ive seen a green LS with a twin turbo set-up at VMP during inspection .. Dude was pretty cool, and i gave him props for the TT set-up.. he hadnt run it yet, but expected it to run 13s non tuned that day.
I never got to see him run or hear about it
Old Sep 30, 2005 | 09:32 AM
h4x's Avatar
h4x
Actually, the guy on HMT made a twin-turbo LSvtec...and he built it in a week....and it cost him $700 all aruond (yay for fourty dollar turbos), AND it was in a CRX.
Just nuts stuff.
Old Sep 30, 2005 | 10:40 AM
Bitchin_Teg's Avatar
Default Re: (h4x)
In Europe mini's with B16a's and even the B18c5's are quite common. The mini clubman is used. With some front end work and reversing the way the hood opens a B16a can be fitted. these mini's can do 0-60 in 5 seconds stock. (on a b16a)
Old Sep 30, 2005 | 10:50 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Fitting a B-series engine in an old mini is tight enough as it is... adding 2 turbos and plumbing seem pretty much impossible. I would definitely have to see pics to believe it.
