car died in 2nd gear
Old Mar 2, 2002 | 10:01 PM
redteg1's Avatar
Default car died in 2nd gear
i was coming back home tonite and my gsr was in 2nd gear coming to a stop sign going about 5-10 mph it started to stall out and die. i pulled over onto the shoulder and tried to start my car up again it turned a couple times but engine sounded like it started an idle for half a second before it died again. i tried a couple more times and never started up but just a little shudder from the engine. i waited like 5 min w/the car off...tried again and it started up. so i went to the gas station i was near empty and checked my oil....no oil at all reading on the dipstick...maybe i could be burning oil? and no compression out of cyl#2. wat could it be? im thinking oil
Old Mar 3, 2002 | 12:52 AM
Kamin's Avatar
Default Re: car died in 2nd gear (redteg1)
summary: NO oil? NO compression on cyl 2?
now when you say NO compression do you mean very low or does it not get a reading?
make sure the tester is completley sealed too man. cause if it is you have a severe problem.
change your oil ASAP check for leaks when you put the new oil in.
Old Mar 3, 2002 | 12:07 PM
redteg1's Avatar
Default Re: car died in 2nd gear (KAMiN)
compression comes up to about 10....compared to the 210,190 and 200 in other cylinders
Old Mar 3, 2002 | 12:18 PM
Kamin's Avatar
ouch...
add some oil check for leaks.
i got a bad feeling tho.
Old Mar 3, 2002 | 12:43 PM
redteg1's Avatar
like wat??
jonyi27
Apr 21, 2014 11:55 AM
jdmwojo
Jan 29, 2010 01:57 PM
fernando.
13
Jul 7, 2009 01:33 PM
tomu06
May 27, 2009 11:26 AM
Bbasso
Sep 17, 2003 03:22 PM
