gt28rs = Full Boost at 6000 rpm
Old Sep 29, 2005 | 03:16 PM
00civicsohc's Avatar
Default gt28rs = Full Boost at 6000 rpm
Hey i have a 2000 civic d16y8 and i have a gt28rs, forge bov, forge fmic, 440cc, 2.5"downpipe to stock cat to 2.25" piping on a magnaflow muffler, and tuned by greddy e-manage. I am putting down 206 whp and 163 wtq on a inaccurate mustang dyno on about 8.5 psi. Anyways i make full boost around 6000 rpm and i know it should be around 4000 rpm. I have made a little tester and checked for boost leaks and found a 2 little pinholes in my charge piping and got them rewelded and it didnt seem to help the spool at all. My tuner said he also checked the internal wastegate and says its working right. He doesnt believe me that my turbo should be making full boost around 4000 rpm and says my motor is too small to do that and i have a "big" turbo. Also at around 6800 rpm i feel the power drop dramatically and takes forever to reach my usually shifting point at 7200 rpm. The tuner also says i cant flow enough air this high in the rpms and that is making this loss of power. But i dont think it should drop that hard. My timing was retarded about 23 degrees and my air/fuels are between 12-11.5. I would show you my air/fuel and dyno sheets but i cant seem to figure out how to post them. Any help on getting my turbo to spool a lot faster and have better top end would be appreciated. Thanks.
Old Sep 29, 2005 | 03:57 PM
nfn15037's Avatar
Default Re: gt28rs = Full Boost at 6000 rpm (00civicsohc)
First off, find a tuner who knows what the **** they are doing, this guy sounds like a moron. The first thing I would check is how the wastegate actuator rod is set then go from there.
Old Sep 29, 2005 | 04:11 PM
*Boostwerks*'s Avatar
Default Re: gt28rs = Full Boost at 6000 rpm (nfn15037)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfn15037 &raquo;</TD></TR><TR><TD CLASS="quote">First off, find a tuner who knows what the **** they are doing, this guy sounds like a moron. The first thing I would check is how the wastegate actuator rod is set then go from there.</TD></TR></TABLE>
Indeed.
Do you have a boost controller? If so, try taking it off, and just hooking the WG line to the <U>intake manifold</U>.
Also, timing has a very important part in spool up. If timing was pulled in low RPMs that could be a major contributor. I'm not really sure what you mean when you say the "timing has been retarded to 23degrees". Is that at full boost, or base timing...or what?
Also the 2.5" DP going to a 2.25" exhaust might come into play as well. The larger the exhaust, the faster the spool.
Just throwing out some ideas. Any pics?
Old Sep 29, 2005 | 04:25 PM
ATS*Mark's Avatar
OG triple OG
Default Re: gt28rs = Full Boost at 6000 rpm (Bryson)
damn i get 6k spool on my y8 with a gt35e on it lol
Old Sep 30, 2005 | 11:14 AM
yee SERIOUS's Avatar
oh man, u need a new tuner. and maybe check your vaccum lines.
Old Sep 30, 2005 | 12:04 PM
.RTErnie's Avatar
Default Re: (undercoverdc2)
THis is interesting.....you guys are talking about spool up time being related to ignition timing....
Old Sep 30, 2005 | 12:14 PM
ComputerJLT's Avatar
Definatley dont go back to that "tuner"
As far as your problem; it could be a bad turbo; leak in the exhaust before the turbo; stuck open wastegate etc.
it could also be that the turbo is spooling like it should it just slowly creeps to 6k making you think its not spooling till then. My garrett t3/t04e on my d16z6 spools around 5k and creeps up some because the turbo is shot and i still have some small exhaust leaks.
And loosing power up top could be a number of things; most likely your idiot tuner has afr's up there in the ultra-rich range (&lt; 10:1); if thats the case you'll make no power. between about 6 and 7 on my car my afr's go from 11.5-richer than 10:1 and i lose all power. i'm working on fixing that with my tune
Old Sep 30, 2005 | 12:25 PM
nfn15037's Avatar
Default Re: (RTErnie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTErnie &raquo;</TD></TR><TR><TD CLASS="quote">THis is interesting.....you guys are talking about spool up time being related to ignition timing....</TD></TR></TABLE>
Sorry did you have something to add? Spool is most definately affected by ignition timing.
Old Sep 30, 2005 | 12:40 PM
pissedoffsol's Avatar
25 Year Member
Default Re: (nfn15037)
stock cat? wtf... thats why you aren't making any power.
as for the spool, what are you tuned with? got a bin you could post?
Old Sep 30, 2005 | 01:52 PM
nfn15037's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00civicsohc &raquo;</TD></TR><TR><TD CLASS="quote"> tuned by greddy e-manage. </TD></TR></TABLE>
Old Sep 30, 2005 | 02:25 PM
25 Year Member
bah, didin't even see that.
but that is problem half of the problem too... tuning with a piggy back
Old Sep 30, 2005 | 03:04 PM
nfn15037's Avatar
Default Re: gt28rs = Full Boost at 6000 rpm (pissedoffsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pissedoffsol &raquo;</TD></TR><TR><TD CLASS="quote">bah, didin't even see that.
but that is problem half of the problem too... tuning with a piggy back</TD></TR></TABLE>
Agreed! I suppose though even if the ignition maps were totally fux0red, he would still be seeing full boost before 6k with a GT28RS. Sounds like the internal wastegate actuator rod is set too loose to me.
Old Sep 30, 2005 | 08:15 PM
25 Year Member
i'm not too familiar with emanage... but how good is it at tuning ignition maps anyway? at WOT, the ecu runs its set program more or less... it might be reverting to the all-motor oem ignition curve. i don't know much about emanage, but that could be a culprit. a lot of advance = poor spool.
Old Oct 1, 2005 | 12:42 AM
Here are the dyno charts.....
http://www.we-todd-did-racing....x.jpg
Old Oct 1, 2005 | 01:16 AM
spoolin turbo s's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pissedoffsol &raquo;</TD></TR><TR><TD CLASS="quote">a lot of advance = poor spool.</TD></TR></TABLE>
no sir i think you are incorrect here
Old Oct 1, 2005 | 04:03 AM
Oyvind Ryeng's Avatar
Default Re: gt28rs = Full Boost at 6000 rpm (spoolin turbo s)
Later ignition, more burning air/fuel-mix in the exhaust manifold = earlier spool. How do you think anti-lag systems works?
Old Oct 1, 2005 | 06:46 AM
nickromeo's Avatar
rip that cat off and see what your spool is so u can elimante that as an option.
just unbolt the thing and drive around see how it feels. rule it out 1st thing.
Old Oct 1, 2005 | 09:36 AM
Agreed! I suppose though even if the ignition maps were totally fux0red, he would still be seeing full boost before 6k with a GT28RS. Sounds like the internal wastegate actuator rod is set too loose to me.</TD></TR></TABLE>
I didn't know they came with an adjustable rod. If so, this is most definetly the case...
Old Oct 1, 2005 | 09:59 AM
Tchleung's Avatar
Ionno. your dyno plot looks pretty decent for that turbo on your motor at the given psi...
Late spool or not. Looks to me you might be creeping
Old Oct 1, 2005 | 10:02 AM
It looks like hes getting full boost at 4K from the graph (although the graph kinda sucks).
Old Oct 1, 2005 | 10:08 AM
Tchleung's Avatar
That's waht I was thinknig. Looks to be full boost around 4200rpm then it slowly creeps
Old Oct 1, 2005 | 10:13 AM
Default Re: (Tchleung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung &raquo;</TD></TR><TR><TD CLASS="quote">That's waht I was thinknig. Looks to be full boost around 4200rpm then it slowly creeps</TD></TR></TABLE>
Yup...considering that torque just keeps climbing higher, it is definetly creeping.
Old Oct 1, 2005 | 10:26 AM
But if you look at this, the boost curve is slowly getting to full boost which is about 8 psi. Its the green curve.
Old Oct 12, 2005 | 01:38 PM
How could i check my internal wastegate to make sure it is completely closed?
Old Oct 12, 2005 | 02:23 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (00civicsohc)
its creeping for sure.. ar you running off of the wg spring or do you have a boost controller?
