EK sideskirts on EG hatch
Old Sep 29, 2005 | 02:54 PM
Formula's Avatar
Default EK sideskirts on EG hatch
I am going to paint my EG hatch in the near future and am planning to use the OEM, EK Civic style sideskirts. My question is do I use the sideskirts off the hatch or the coupe.
Old Sep 29, 2005 | 02:58 PM
Radyjr's Avatar
Default Re: EK sideskirts on EG hatch (Formula94)
if you use coupe or hatch you have to cut about 1.5-2 inches at the rear
Old Sep 29, 2005 | 03:05 PM
Formula's Avatar
Thanks. I did know that you had to trim the sideskirts a little to make them fit but I didn't know how much. So I guess this means you can use the coupe or hatch sideskirts and it doesn't matter which one.
Old Sep 29, 2005 | 03:13 PM
t0ekn3e's Avatar
coupe and hatch sideskirts are them same, it is the 4 door that is slightly diffrent.
Old Sep 29, 2005 | 03:19 PM
Formula's Avatar
Thanks guys. I'm gona go to my local Honda salvage yard and try to find a set for the cheap. GO JDM!!!!
Old Sep 29, 2005 | 04:22 PM
peacexisxfree's Avatar
Default Re: (t0ekn3e)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0ekn3e &raquo;</TD></TR><TR><TD CLASS="quote">coupe and hatch sideskirts are them same, it is the 4 door that is slightly diffrent.</TD></TR></TABLE>
is this just on ek models? because i know for a fact that 92-95 hb's have a short rocker panel than coupes. i got couple rocker panels and had to hack off at least .5" to make em fit.
Old Sep 29, 2005 | 04:30 PM
t0ekn3e's Avatar
just ek
Old Sep 29, 2005 | 04:46 PM
hookedonvtec's Avatar
Default Re: EK sideskirts on EG hatch (Radyjr)
heres sum on my car. u can see how it looks when u cut it, im tryin to get sum mud guards.
its dirty i know... but drivin to LA to SD twice a day does that to ya haha
Old Sep 29, 2005 | 04:55 PM
banzaiMiyagi's Avatar
looks good
Old Sep 29, 2005 | 04:59 PM
Default Re: (banzaiMiyagi)
one of my favorite things on the car besides whats under the hood lol, its a small but significant change
Old Sep 29, 2005 | 05:00 PM
CHiNkStEr's Avatar
that is a crappy *** custom job of ek sides man. eww. heres how its suppose to look: like OEM no gaps no nothing!!
Old Sep 29, 2005 | 05:09 PM
Default Re: (*****StEr)
how do u figure? because i didnt close up the end? if im gettin mud guards then theres really no point dont u think?
Old Sep 29, 2005 | 05:10 PM
egbuiltright's Avatar
not really a fan of them, but nice car.
Old Sep 29, 2005 | 05:12 PM
CHiNkStEr's Avatar
eh i guess if you get mud gaurds its cool but i dont think the mudgaurds will cover all of the gap around that fender area.
Default Re: (egbuiltright)
theres is not gap besides in the front where i cut it because theres nothin holding it up, lets see a close picture of the red one and see how its done then.
Old Sep 29, 2005 | 05:22 PM
jdmsiR20's Avatar
Default Re: (hookedonvtec)
DAMN you guys i miss my hatch
Old Sep 29, 2005 | 05:23 PM
CHiNkStEr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hookedonvtec &raquo;</TD></TR><TR><TD CLASS="quote">theres is not gap besides in the front where i cut it because theres nothin holding it up, lets see a close picture of the red one and see how its done then.</TD></TR></TABLE>
negative on that, the secret shall not be revealed. hahahah. jp i don't have pics!
Old Sep 29, 2005 | 05:25 PM
CHiNkStEr's Avatar
Default Re: (jdmsiR20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmsiR20 &raquo;</TD></TR><TR><TD CLASS="quote">DAMN you guys i miss my hatch </TD></TR></TABLE>
too bad so sad brother, too bad so sad
Old Sep 29, 2005 | 06:08 PM
KiddEng's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Radyjr &raquo;</TD></TR><TR><TD CLASS="quote">if you use coupe or hatch you have to cut about 1.5-2 inches at the rear</TD></TR></TABLE>
cut off from the front, not the REAR, you want to save the nice flare in the back.
and mud flaps to cover the front hole...
did you guys have to make new holes for the clips? only 1 mount for the clip lined up, i had to make 3 more holes for other clips to hold on the EK skirts.
Modified by KiddEng at 10:43 PM 9/29/2005
Old Sep 29, 2005 | 06:26 PM
Default Re: EK sideskirts on EG hatch (KiddEng)
yea i drilled new holes, the best thing i would recomment would be to put bolts underneath the car too to help hold it in place, that way if u accidentally step on it gettin out of the car it wont rip off.
agreed, to bad so sad lol
Old Sep 29, 2005 | 06:42 PM
KiddEng's Avatar
Default Re: EK sideskirts on EG hatch (hookedonvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hookedonvtec &raquo;</TD></TR><TR><TD CLASS="quote">yea i drilled new holes, the best thing i would recomment would be to put bolts underneath the car too to help hold it in place, that way if u accidentally step on it gettin out of the car it wont rip off.
agreed, to bad so sad lol </TD></TR></TABLE>
good idea, but the holes underneath don't line up well enough to reuse those EG plastic clips/screws... did you make new holes for the bolts also?
Old Sep 30, 2005 | 12:38 AM
i just put my own bolts in there, make sure u use wide washers too so it wont tear.
Old Sep 30, 2005 | 07:31 AM
CHiNkStEr's Avatar
i see that door molding saved your driver side door from a vicious door ding. for keeping your moldings!
Old Sep 30, 2005 | 08:40 AM
mrnicolas's Avatar
I used the mud guards to hide the cut I made in mine. i think i was able to get 4 or 5 of the clips in for the sideskirts.
Old Sep 30, 2005 | 08:46 AM
RedEK9's Avatar
Default Re: (mrnicolas)
Nice^^^^^^^^^^
I didn't have to cut anything to make them fit on mine, It just clips right in...
