Safe to run stock injectors and fuel pump with jrsc?
Old Sep 29, 2005 | 01:09 PM
escape2me's Avatar
Default Safe to run stock injectors and fuel pump with jrsc?
Im should be gettin a jrsc soon and was wandering if the stock injectors and fuel pump would be ok to run for a month or two... until i can get better ones... only at 6 pounds of boost
Old Sep 29, 2005 | 01:12 PM
theSYNDICATE's Avatar
From: Derek Jeter drinks wine coolers,, The Nation, USA
Default Re: Safe to run stock injectors and fuel pump with jrsc? (97 GSR)
I wouldn't run stock injectors. But the stock fuel pump will be fine.
Old Sep 29, 2005 | 01:17 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Safe to run stock injectors and fuel pump with jrsc? (theSYNDICATE)
What kind of fuel system does it come with? Any sort of boost dependent FPR? If it doesn't come with any sort of fuel components, I definitely wouldn't run with a stock setup. Fuel delivery becomes VERY important in boosting situations. VERY.
Old Sep 29, 2005 | 01:18 PM
nholmes's Avatar
I thought we already covered this???
Originally Posted by nholmes
1. Yes
2. Yes
3. Yes
4. No different.
5. Please read: JRSC Basics
If you are that lazy, I'll paste it in here for you:
Out of the Box:
The easiest way to create power is to pressurize the intake, better known as forced induction.
One of the easiest ways to force feed an engine is to use of a supercharger. Jackson Racing (JR), a known name in the Honda and Mazda market, has put together a well-engineered supercharger kit that is 50 state smog legal, carrying a CARB certification. JR use a specially modified supercharger made by Eaton, to accomplish a gain of 40% power.
Out of the box, the supercharger kit (6 PIS) includes just about everything you need:
• New vacuum hoses, fuel pressure regulator (FPR)
• JR electronics
• M-45 or M-62 Eaton supercharger depending on application
• Intake manifold
• Alternator relocation bracket
• Double alternator pulley
• Supercharger belt and tensioner
• Along with throttle body and intake manifold gaskets.
A new fuel filter is required, but not included.
General hand tools and a good knowledge mechanical knowledge are needed to be successful.
Average install time for a professional is about 8~10 hours for a B18B engine and about 12~14 hours for a B18C engine. The kit is marketed as a "bolt-on" and a successful install can be accomplished over a weekend's time. Instructions are through and are detailed enough for the amateur mechanic, but expect a more realistic time of 20 to 28 hours if this is your first attempt at modifying your engine. Having a Helms Manuel is highly suggested, for any engine project.
One of the most general questions asked is "what else do I need." In the most simple terms, nothing additional is needed. It's very possible to operate on a stock kit with only dyno tuning and moderate timing setting. Most gear heads do seek further performance and reliability gains, so the following will help guide you in your decision.
Basic Setup:
Even though the Jackson Racing Supercharger can operate with a high level of reliability, there are some aftermarket items not included in the kit that not only make the engine more reliable, but also support future power upgrades. Besides, who wants to be stock? The following items are suggested for safety and reliability.
One heat range colder plug (NGK BCPR7ES)
High-flow fuel pump (Walbro GS-342 or better)
Cartech FMU (20005i or 2025 models)
JR BTC or MSD 6BTM
Boost and mechanical fuel pressure gauges
Dyno tuning
Products, such as the Cartech, BTC, and fuel pump, were chosen to compliment the supercharger and add even more reliability. The Cartech FMU is far superior to the JR FPR (fuel pressure regulator) in many ways. The Cartech FMU is a rise rate fuel pressure regulator; similar to the one JR gives you with their kits. But that's where the similarity ends.
The Cartech 20005i or 2025 (the one you need for S/C engine) allows you to change the ramping, ratios, and allows one to tune larger injectors; these are all things that JR unit can't do.
Ramping: The JR unit does not increase fuel pressure until positive manifold pressure is reached; this is the area where tip-in detonation is common. Also, a "bog" can be felt when the JR unit makes a sudden change in fuel pressure, during this transition. The Cartech has a bleeder valve that can be adjusted to start raising fuel pressure as low as 10" mercury; this makes for a smooth transition to boost and lessens tip-in.
Ratios: The JR unit is set to a 5:1 ratio, meaning for every 1 LB of manifold pressure, fuel pressure will be raised 5LB. So on a stock (6LB) blower, the max fuel pressure should be (6x5=30 + 52(stock GS-R fuel pressure)= 82LB). But many of us see +100LB. why? The reason is the JR FPR makes adjustments based on manifold pressure, which can be higher than 6LB, due to restrictive a header/exhaust slowing the flow and causing the air to "clog up." So instead of the FPR seeing 6LB, it sees 8LB and bumps up fuel pressure an additional 10LB; too rich and robs power. The Cartech's ratios are adjustable and can be set as low as 1:1. On a dyno, several people note a 3.8~4.2:1 as making "good power;" these numbers will only mean something to your set-up and are not transferable to another's setup.
Tuning with bigger injectors: The JR FPR just can't do it. When used in conjunction with an AEM FPR/B&M FPR, the Cartech can dial in those fat injectors for a nice idle.
The fuel pressure gauges will allow the tuner to dial in fuel pressure. The JR BTC will allow for detonation control and give back what would be lost timing and power, for the low end. The fuel pump is self explanatory, as the stock pump just can't move the volume need ed. Changing to a copper plug, of one heat range colder (NGK BCPR7ES-11 stock #1095 for B-series engines) will also aid in detonation control and are cheaper on the wallet to replace. One of the most important aspects is dyno tuning; it is near impossible to extract power by "seat of the pants" tuning.
Old Sep 29, 2005 | 01:33 PM
shamoo's Avatar
Default Re: Safe to run stock injectors and fuel pump with jrsc? (nholmes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nholmes &raquo;</TD></TR><TR><TD CLASS="quote">I thought we already covered this???</TD></TR></TABLE>
Weird, why did he ask again. The other post answered everything perfectly and in great detail as well. Weird.
Old Sep 29, 2005 | 04:00 PM
BSP-DC2
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97 GSR &raquo;</TD></TR><TR><TD CLASS="quote">Im should be gettin a jrsc soon and was wandering if the stock injectors and fuel pump would be ok to run for a month or two... until i can get better ones... only at 6 pounds of boost</TD></TR></TABLE>
Ive been following you around for awhile about your jrsc threads, it must of been what 9 months since you said you were getting a jrsc? hah, i know because i was looking for one for mine 2 months after you started
Old Sep 29, 2005 | 04:01 PM
BSP-DC2
Guest
Posts: n/a
yes it should be fine, if you want to be safe upgrade the fuel pump which i might have for sale in a bit
Old Sep 29, 2005 | 04:17 PM
Chewie's Avatar
Default Re: (BSP-DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BSP-DC2 &raquo;</TD></TR><TR><TD CLASS="quote">Ive been following you around for awhile about your jrsc threads, it must of been what 9 months since you said you were getting a jrsc? hah, i know because i was looking for one for mine 2 months after you started</TD></TR></TABLE>
e-stalker
Old Sep 29, 2005 | 10:52 PM
BSP-DC2
Guest
Posts: n/a
Default Re: (Chewie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chewie &raquo;</TD></TR><TR><TD CLASS="quote">
e-stalker</TD></TR></TABLE>
It was mainly because i wanted to see what he was going to do because i was in the same boat as him
Old Sep 30, 2005 | 07:29 AM
simon98h22's Avatar
Default Re: Safe to run stock injectors and fuel pump with jrsc? (shamoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo &raquo;</TD></TR><TR><TD CLASS="quote">What kind of fuel system does it come with? Any sort of boost dependent FPR? If it doesn't come with any sort of fuel components, I definitely wouldn't run with a stock setup. Fuel delivery becomes VERY important in boosting situations. VERY.</TD></TR></TABLE>
Agreed.
Thanks for the post nholmes, good read.
GsrVtec
Sep 6, 2006 01:06 PM
Pfieff
Jun 30, 2003 02:30 PM
keebler65
May 30, 2003 09:47 AM
uNF$@#!
Aug 6, 2002 07:45 PM
