rear window washer is not sparying out washer fluid
Old Sep 29, 2005 | 11:13 AM
punx5997's Avatar
Default rear window washer is not sparying out washer fluid
I hear the pump working and can see pressure being applied in the line but there is no fluid moving through. I haven't checked to see if the line is disconnected but nothing has happend to the car to remove the line from the pump. If anyone has suggestions I would love to hear them. thanks.
Old Sep 29, 2005 | 11:19 AM
Racermech's Avatar
Default Re: rear window washer is not sparying out washer fluid (punx5997)
take a pin and clean the littlee nozzle hole out, you could of got a little wax or something stuck in it
Old Sep 29, 2005 | 11:27 AM
h4x's Avatar
h4x
Do they actually spray? All the integras ive seen it just kind of drizzles out...haha
Old Sep 29, 2005 | 12:45 PM
Jcards26's Avatar
Default Re: (h4x)
ya mine doesnt spray out, but then again i might have the same problem
Old Sep 29, 2005 | 12:47 PM
GDR888's Avatar
Default Re: rear window washer is not sparying out washer fluid (Racermech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racermech &raquo;</TD></TR><TR><TD CLASS="quote">take a pin and clean the littlee nozzle hole out, you could of got a little wax or something stuck in it</TD></TR></TABLE>
Old Sep 29, 2005 | 01:17 PM
Mazinger's Avatar
Default Re: rear window washer is not sparying out washer fluid (GDR888)
Yep. Take a pin. Mine was clogged at the nozzle.
Old Sep 29, 2005 | 09:04 PM
punx5997's Avatar
Default Re: rear window washer is not sparying out washer fluid (Mazinger)
yeah it never sprayed, I didn't know what other word to use. thanks for the tips, I'll try taking a pin to it tomorrow!
Old Oct 1, 2005 | 10:18 PM
punx5997's Avatar
I took a pin and cleaned out the nozzle but nothing came out of it and the problem still ensues. The next day I'll have some good time to look at it will be tuesday so if there's anything else I should be looking for let me know. Thanks for all the help!
Old Oct 2, 2005 | 02:12 AM
Sifu's Avatar
Take out the roof lining and see if theres anything wrong with the line going from the pump to the nozzle.
Also stop spraying it until you find the fault. On my friends old g2 he kept spraying trying to figure out the problem and ended up having water all over inside!
Old Oct 2, 2005 | 06:41 AM
HiRevn's Avatar
Default Re: (Sifu)
Maybe the line is clogged up. This happened to my brother's 1st Gen because he never used it.
I've had my car since it was brand new and it never really sprayed. It just trickled down the back window.
Old Oct 2, 2005 | 07:37 AM
Backk InTheDA's Avatar
I hate everything
Default Re: (h4x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h4x &raquo;</TD></TR><TR><TD CLASS="quote">Do they actually spray? All the integras ive seen it just kind of drizzles out...haha</TD></TR></TABLE>
No they spray, i've heard stories of idiot drivers behind a teg, and the owner uses it to squirt there car.
Ownage to the extreme
Importn2oRacer
Jan 22, 2010 11:43 PM
TooManyTickets
30
Jul 16, 2007 09:45 PM
Wiggler
Jan 13, 2007 01:10 PM
vimsen
Jul 18, 2002 08:23 AM
94preludeVTEC
Dec 12, 2001 08:56 AM
