B 16 V-tec
Old Sep 29, 2005 | 09:13 AM
Sir90CivicHatch's Avatar
Default B 16 V-tec
I have a 1993 del sol thats a D-15. iwant to swap to a B-16 V-tec motor. I already have the head what other parts will i nedd to make it a true B-16 V-tec?
Old Sep 29, 2005 | 09:16 AM
viskii420's Avatar
u need the trenny and the block.. ecu..
i would go w. LS bottom and s80 transmission..
Old Sep 29, 2005 | 09:20 AM
Archidictus's Avatar
Unceasing Measure
Default Re: B 16 V-tec (Sir90CivicHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sir90CivicHatch &raquo;</TD></TR><TR><TD CLASS="quote">I have a 1993 del sol thats a D-15. iwant to swap to a B-16 V-tec motor. I already have the head what other parts will i nedd to make it a true B-16 V-tec?</TD></TR></TABLE>
1.) there are no dashes between engine codes, i.e. "D15B8" or "B16A2"
2.) VTEC is an acronym for "variable valve timing and lift electronic control". There is no dash, there is no "tech".
3.) if you only have the head, you need the rest of the engine and the transmission and the axles and the ECU and, and, and. You need to do some research before you attemp to do this thing about which you obviously know nothing. Use the search function in the upper right-hand corner of this page.
Old Sep 29, 2005 | 10:48 AM
spoonsports12's Avatar
ur better of sellin the head and buyin a complete swap... puttin togther a swap ull get nickled and dimed like crazy...
Old Sep 29, 2005 | 10:53 AM
SirRevvs's Avatar
Default Re: B 16 V-tec (spoonsports12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonsports12 &raquo;</TD></TR><TR><TD CLASS="quote">ur better of sellin the head and buyin a complete swap... puttin togther a swap ull get nickled and dimed like crazy...</TD></TR></TABLE>
Have to agree with this guy. Sell the head for $500 and buy a swap for $1500
Old Sep 29, 2005 | 11:03 AM
FalkenSiR's Avatar
Default Re: B 16 V-tec (SirRevvs)
Like they say, if you have to ask, don't do it. Just keep reading around for a few months and then you'll get it.
JdelMsolG
Jan 24, 2007 10:49 PM
jdmEF8racer
Oct 1, 2006 03:23 PM
codyb13
Oct 19, 2005 06:21 PM
drunknmonkey18
Oct 23, 2004 09:01 AM
96tegra
Jul 7, 2003 07:55 PM
